Re: 5/8 stud ?
[Re: rickraw]
#3148185
06/02/23 12:32 PM
06/02/23 12:32 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Not sure but I have 5/8" studs on my street car and it has SSBC rear disc brakes and an parking brake and had no issues. But again not the same set up. The rear of the stud does protrude a bit, uses a locking jam nut, maybe 3/8" stick out on rear.
Re: 5/8 stud ?
[Re: rickraw]
#3148258
06/02/23 03:44 PM
06/02/23 03:44 PM
Al_Alguire
Las Vegas
Yes they do I actually have a couple sets. Can measure the head on one gimme a minute
The screw in stud is just under 3/8" total stickout behind the axle,
Thew shank style studs, and I just measured three sets, two strange and one from Mar Williams are all just under 3/4" stockoout past the rear of the flange.
I am not a huge fan of the screw in ones as they use a screw in "shank". Just a personal preference.
Re: 5/8 stud ?
[Re: rickraw]
#3148328
06/02/23 10:14 PM
06/02/23 10:14 PM
Posts: 1,363 Out of the State of Confusion
blue_stocker
I've had the same bolt-sleeve 5/8" studs in my Strange axles over 35 years and no problems. Grantid, my car is just a stock eliminator car but I've never had any problems. Keep the nuts torqued tight and you shouldn't have any problems, after all there's quite the difference between 1/2" and 5/8" in strength.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
Re: 5/8 stud ?
[Re: rickraw]
#3148426
06/03/23 02:58 PM
06/03/23 02:58 PM
Posts: 19,456 north of coder
moparx
I have no other choice but to use the strange studs.I’m getting new mark Williams axles made up with both stud sizes. Present axles have 1/2 strange screw in bolts which are slightly bent. so you are going with the 5/8" studs with the 1/2" screw in shanks or 5/8"-5/8" screw in shanks ? if getting new axles, why both stud sizes ?
Re: 5/8 stud ?
[Re: rickraw]
#3148445
06/03/23 03:56 PM
06/03/23 03:56 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have no other choice but to use the strange studs.I’m getting new mark Williams axles made up with both stud sizes. Present axles have 1/2 strange screw in bolts which are slightly bent. They are a bit of a PIA to install. I know since they are in my axles. That said, no issues since. If it needs good aftermarket axles, it needs 5/8" studs. That's a no brainer.
Re: 5/8 stud ?
[Re: mopowers]
#3148538
06/04/23 07:59 AM
06/04/23 07:59 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
What wheels are you guys running with your 5/8" studs. I'm learning that wheel options are kind of limited with the 5/8" studs. As long as they are not an acorn seat wheel they should work with the big studs. This is providing the wheel has enough room around the lug to use the proper spacer and larger nut required. Both my street wheels and race wheels needed no mods when I moved to 5/8 studs. I am speaking for the 5/8 drive lug with the smooth shank on the stud and fine threads on the end. I know there is a 5/8 fully threaded stud that I believe is used in some circle track stuff and I have no idea what works with those.
68 Barracuda Formula S 340
Re: 5/8 stud ?
[Re: Bad340fish]
#3148678
06/04/23 07:16 PM
06/04/23 07:16 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
What wheels are you guys running with your 5/8" studs. I'm learning that wheel options are kind of limited with the 5/8" studs. As long as they are not an acorn seat wheel they should work with the big studs. This is providing the wheel has enough room around the lug to use the proper spacer and larger nut required. Both my street wheels and race wheels needed no mods when I moved to 5/8 studs. I am speaking for the 5/8 drive lug with the smooth shank on the stud and fine threads on the end. I know there is a 5/8 fully threaded stud that I believe is used in some circle track stuff and I have no idea what works with those. What wheels do you run on the street and what do you race with? I've got Draglites now, but looking to go a different direction. My 5/8" studs have the 11/16" smooth shank if I remember correctly.
