5/8 stud ? #3148101
06/02/23 07:19 AM
06/02/23 07:19 AM
Ambridge, Pa.
rickraw Online content OP
rickraw  Online Content OP
Ambridge, Pa.
I’m getting new axles, will 5/8 studs work with wilwood rear disc with park brake? Old screw in studs only have a 3/16 thick head, just wondered if there would be a clearance issue with shoe hardware. Thanx.
Re: 5/8 stud ? [Re: rickraw] #3148185
06/02/23 12:32 PM
06/02/23 12:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure but I have 5/8" studs on my street car and it has SSBC rear disc brakes and an parking brake and had no issues. But again not the same set up. The rear of the stud does protrude a bit, uses a locking jam nut, maybe 3/8" stick out on rear.
Re: 5/8 stud ? [Re: Al_Alguire] #3148256
06/02/23 03:43 PM
06/02/23 03:43 PM
Ambridge, Pa.
Ambridge, Pa.
Yea I see the jamb nut is too thick for my application. I did find that strange has a 5/8 screw in stud with a 0.215 thick head which will work, plus it has a locator sleeve to center the rim on the studs. Thanx for the reply.
Re: 5/8 stud ? [Re: rickraw] #3148258
06/02/23 03:44 PM
06/02/23 03:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes they do I actually have a couple sets. Can measure the head on one gimme a minute
The screw in stud is just under 3/8" total stickout behind the axle,
Thew shank style studs, and I just measured three sets, two strange and one from Mar Williams are all just under 3/4" stockoout past the rear of the flange.
I am not a huge fan of the screw in ones as they use a screw in "shank". Just a personal preference.
Re: 5/8 stud ? [Re: Al_Alguire] #3148279
06/02/23 05:14 PM
06/02/23 05:14 PM
Ambridge, Pa.
Ambridge, Pa.
I have no other choice but to use the strange studs.I’m getting new mark Williams axles made up with both stud sizes. Present axles have 1/2 strange screw in bolts which are slightly bent.
Re: 5/8 stud ? [Re: rickraw] #3148328
06/02/23 10:14 PM
06/02/23 10:14 PM
Out of the State of Confusion
blue_stocker Offline
I've had the same bolt-sleeve 5/8" studs in my Strange axles over 35 years and no problems. Grantid, my car is just a stock eliminator car but I've never had any problems. Keep the nuts torqued tight and you shouldn't have any problems, after all there's quite the difference between 1/2" and 5/8" in strength.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: 5/8 stud ? [Re: rickraw] #3148426
06/03/23 02:58 PM
06/03/23 02:58 PM
moparx Offline
moparx  Offline
so you are going with the 5/8" studs with the 1/2" screw in shanks or 5/8"-5/8" screw in shanks ?
if getting new axles, why both stud sizes ?
beer
Re: 5/8 stud ? [Re: rickraw] #3148445
06/03/23 03:56 PM
06/03/23 03:56 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
They are a bit of a PIA to install. I know since they are in my axles. That said, no issues since.
If it needs good aftermarket axles, it needs 5/8" studs. That's a no brainer.
Re: 5/8 stud ? [Re: CMcAllister] #3148449
06/03/23 04:11 PM
06/03/23 04:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nothing wrong with a 5/8" screw in stud I just PREFER a shanked stud of the correct length for the wheel I am running. Kinda like a 4 lionk or ladder bar bolt, it need to be completely on the shank not on the threads is all, I also like to keep the studs as short as possible. But then again I have run a few sets of titanium studs and bolts before. If you want some sticker shock but alot of weight savings smile
https://www.ti64.com/titanium-wheel-centers-studs-beadlocks-s/110818.htm
Re: 5/8 stud ? [Re: Al_Alguire] #3148465
06/03/23 05:45 PM
06/03/23 05:45 PM
Ambridge, Pa.
Ambridge, Pa.
I saw those titanium studs, definitely a shocker. Moparx, I was going 1/2” with arp studs originally but, I would’ve had to grind off most of the heads for park brake clearance and Mark Williams offered both sizes so I left it at that.
Re: 5/8 stud ? [Re: rickraw] #3148510
06/03/23 10:52 PM
06/03/23 10:52 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What wheels are you guys running with your 5/8" studs. I'm learning that wheel options are kind of limited with the 5/8" studs.
Re: 5/8 stud ? [Re: mopowers] #3148538
06/04/23 07:59 AM
06/04/23 07:59 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
As long as they are not an acorn seat wheel they should work with the big studs. This is providing the wheel has enough room around the lug to use the proper spacer and larger nut required. Both my street wheels and race wheels needed no mods when I moved to 5/8 studs.
I am speaking for the 5/8 drive lug with the smooth shank on the stud and fine threads on the end. I know there is a 5/8 fully threaded stud that I believe is used in some circle track stuff and I have no idea what works with those.
68 Barracuda Formula S 340
Re: 5/8 stud ? [Re: Bad340fish] #3148678
06/04/23 07:16 PM
06/04/23 07:16 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What wheels do you run on the street and what do you race with? I've got Draglites now, but looking to go a different direction. My 5/8" studs have the 11/16" smooth shank if I remember correctly.
