Re: headers glowing red at idle
[Re: dart games]
#3147757
05/31/23 08:10 AM
05/31/23 08:10 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Did you spray around the carb base to check for a vacuum leak there?
[Re: dart games]
#3147896
05/31/23 08:31 PM
05/31/23 08:31 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
8 sec cuda,yes.now its time to attack the carb,carb gurus chime in.thumper wont give me tuning advice and its his carb.so did research on power valves.said if the power valve is too low will run lean.which makes me think somethings wrong with the carb when i put my hand over the primarys and it idles fine,wasnt looking at the headers at that time..so i ordered block off plugs for the power valve also stated in the research by blocking off power vavle will enrich it has 88 jets should i go higher in jet sizes.its a shame all spped shops in st.louis is gone.so theres no where to get block offs at.so in a few day will get them.not sure what jets is in the idle circuts.its a 3 circut that been converted into 2 circut I find that hard to believe that Thumper won't help. He spent a lot of time on the phone helping me with a carb that he didn't build, several calls in fact. I do have one of his carbs now and he has always helped with it too. Do you have an AFR meter on it?
[Re: dart games]
#3147946
06/01/23 09:10 AM
06/01/23 09:10 AM
Thumperdart
State of confusion
Make sure when you talk about me that you keep it real and honest and I HAVE tried to help you and the p/v jets etc have ZERO to do with glowing headers....Get it together before you try and throw me under the bus there buddy...
[Re: Thumperdart]
#3147953
06/01/23 09:47 AM
06/01/23 09:47 AM
Posts: 3,024 NY
B1duster
NY
[Re: B1duster]
#3147956
06/01/23 09:55 AM
06/01/23 09:55 AM
an8sec70cuda
Since you have the timing cover off...put a degree wheel on it and find out where the cam is. Guessing where it is by going off the marks on the timing set isn't gonna do you any favors. If it's not where it should be, correct it and try again. If the cam is installed OK, put it back together, then adjust the timing by hand and see what happens. Do this before you screw w/ the carb. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: bonefish]
#3148234
06/02/23 02:59 PM
06/02/23 02:59 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
dont b and rb timing covers have the tab in a diffrent place No if they are the same year. Mopar has used three different timing covers since the early 1960. 1958 to 1966 or 1967 (CRS) and then change them again in the mid 1970s ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Thye also change the dampeners with the timing covers in 1966 or 1967 with the dampener change, They move TDC from the top to the middle of the timing tab ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: FastmOp]
#3150144
06/10/23 01:33 AM
06/10/23 01:33 AM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
Someone is going to buy this for a song and have it fixed in a day.
