Stock truck 6.4 motors, how much power and costs used from a
#3098804
12/01/22 10:50 PM
12/01/22 10:50 PM
Posts: 43,347 Bend,OR USA
Cab_Burge
I'm thinking about finding and buying a used 6.4 stick shift motor out of a wreck truck, how much torque and HP do they make stock, not a special order version ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) if they made them ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I have 1967 Satellite two door hardtop that was strip by a junkyard of the drivetrain, front group and interior including the dash so I'm thinking it will make a good car for learning about the new hemi motors with a single carb on it for bracket racing ![help help](/ubbthreads/images/graemlins/custom/smilie_help.gif) I may consider trying to use the stock fuel injection on it if I can find a kit to convert it to an easy to use ECU kit that won't break my bank funds ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) All help and any comments on these motors and my intend use appreciated, THANKS in advance ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Cab I Google those pickup motors and saw that the 2021 pick up motors are suppose to have 410 HP with 429 Ft. Lbs. torque, I didn't think to write the RPM down for either one ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) That should work okay to start with, learn first and then try hopping it up ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
Re: Stock truck 6.4 motors, how much power and costs used from a
[Re: Cab_Burge]
#3098984
12/02/22 04:21 PM
12/02/22 04:21 PM
Posts: 2,882 Pattison Texas
CSK
Pattison Texas
I was thinking they used the same 6.4 thats in my Challenger, but I guess I was wrong, interesting
[Re: mgoblue9798]
#3099276
12/03/22 05:59 PM
12/03/22 05:59 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Sound German auto has the 8 speed controller available
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: Cab_Burge]
#3099842
12/05/22 03:29 PM
12/05/22 03:29 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
No stick shift 6.4s that I am aware of. That said why would it matter?
410 HP bone stock, put in good headers when you do a swap and tune whatever system you run to control it and you should make minimum 450 HP unless you go to a very crappy intake like the low rise mopar single plane.
Whatever controls your existing alternator will control the factory one on the hemi, it is just a denso and the field is manipulated just like it was in the old cars to maintain a certain voltage. Yes it would be nice to have it all in one but it is not a big deal.
[Re: gremlinsteve]
#3100287
12/07/22 12:20 AM
12/07/22 12:20 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
They do but it is a cool grand. Not going to pay that on top of the cost of the Holley Term X or other a/m hemi control. Maybe someone will come out with a simple swap using factory computers soon that doesn't cost and arm and a leg. Sound German auto has the 8 speed controller available
[Re: cudadoug]
#3100450
12/07/22 03:40 PM
12/07/22 03:40 PM
HotRodDave
Kalispell Mt.
They made 361 HP and the power was still climbing rapidly when they shut it down, they had seafoam in the oil when they did it and a severly mismatched intake that would only start working at the RPM they stopped at. In my opinion that was a pretty pointless test, a stock 5.7 makes more with less CID, inferior heads, and smaller cam.
[Re: PLUM_72]
#3146180
05/22/23 01:34 PM
05/22/23 01:34 PM
Cab_Burge
Update, my wife died Friday morning after fighting lung cancer for the last three years, may she now rest in peace ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif) ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I'll probably start looking next week for a core motor after her funeral ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I'm hoping that by keeping busy on projects I won't focus as much on her being gone ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: Cab_Burge]
#3146205
05/22/23 03:01 PM
05/22/23 03:01 PM
CSK
Pattison Texas
Very sorry for your loss !!!!!!!
[Re: A990]
#3146237
05/22/23 06:43 PM
05/22/23 06:43 PM
Posts: 1,414 Central Pa
moparjim79
Central Pa
[Re: moparjim79]
#3146244
05/22/23 07:16 PM
05/22/23 07:16 PM
Posts: 15,952 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Oh Cab I'm so sorry brother. May she rest in peace and I know you find comfort in that. Sink yourself into Mopars and we are here for you brother.
Facts are stubborn things.
[Re: larrymopar360]
#3146256
05/22/23 07:58 PM
05/22/23 07:58 PM
Posts: 1,560 Michigan
Kiddart
Very Sorry for your loss Cab.
Prayers sent your way!!
Thank you Kiddart
[Re: CSK]
#3146263
05/22/23 08:20 PM
05/22/23 08:20 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I was thinking they used the same 6.4 thats in my Challenger, but I guess I was wrong, interesting Aren't they same 6.4, different exhaust manifolds? I believe that's the case on the 5.7 truck versus cars.
