Stock truck 6.4 motors, how much power and costs used from a
#3098804
12/01/22 10:50 PM
12/01/22 10:50 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
I'm thinking about finding and buying a used 6.4 stick shift motor out of a wreck truck, how much torque and HP do they make stock, not a special order version if they made them I have 1967 Satellite two door hardtop that was strip by a junkyard of the drivetrain, front group and interior including the dash so I'm thinking it will make a good car for learning about the new hemi motors with a single carb on it for bracket racing I may consider trying to use the stock fuel injection on it if I can find a kit to convert it to an easy to use ECU kit that won't break my bank funds All help and any comments on these motors and my intend use appreciated, THANKS in advance Cab I Google those pickup motors and saw that the 2021 pick up motors are suppose to have 410 HP with 429 Ft. Lbs. torque, I didn't think to write the RPM down for either one That should work okay to start with, learn first and then try hopping it up
Re: Stock truck 6.4 motors, how much power and costs used from a
[Re: Cab_Burge]
#3098984
12/02/22 04:21 PM
12/02/22 04:21 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I was thinking they used the same 6.4 thats in my Challenger, but I guess I was wrong, interesting
[Re: mgoblue9798]
#3099276
12/03/22 05:59 PM
12/03/22 05:59 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Sound German auto has the 8 speed controller available
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: Cab_Burge]
#3099842
12/05/22 03:29 PM
12/05/22 03:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
No stick shift 6.4s that I am aware of. That said why would it matter?
410 HP bone stock, put in good headers when you do a swap and tune whatever system you run to control it and you should make minimum 450 HP unless you go to a very crappy intake like the low rise mopar single plane.
Whatever controls your existing alternator will control the factory one on the hemi, it is just a denso and the field is manipulated just like it was in the old cars to maintain a certain voltage. Yes it would be nice to have it all in one but it is not a big deal.
[Re: gremlinsteve]
#3100287
12/07/22 12:20 AM
12/07/22 12:20 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
They do but it is a cool grand. Not going to pay that on top of the cost of the Holley Term X or other a/m hemi control. Maybe someone will come out with a simple swap using factory computers soon that doesn't cost and arm and a leg. Sound German auto has the 8 speed controller available
[Re: cudadoug]
#3100450
12/07/22 03:40 PM
12/07/22 03:40 PM
HotRodDave
Kalispell Mt.
They made 361 HP and the power was still climbing rapidly when they shut it down, they had seafoam in the oil when they did it and a severly mismatched intake that would only start working at the RPM they stopped at. In my opinion that was a pretty pointless test, a stock 5.7 makes more with less CID, inferior heads, and smaller cam.
[Re: PLUM_72]
#3146180
05/22/23 01:34 PM
05/22/23 01:34 PM
Cab_Burge
Update, my wife died Friday morning after fighting lung cancer for the last three years, may she now rest in peace I'll probably start looking next week for a core motor after her funeral I'm hoping that by keeping busy on projects I won't focus as much on her being gone
[Re: Cab_Burge]
#3146205
05/22/23 03:01 PM
05/22/23 03:01 PM
CSK
Pattison Texas
Very sorry for your loss !!!!!!!
[Re: A990]
#3146237
05/22/23 06:43 PM
05/22/23 06:43 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
[Re: moparjim79]
#3146244
05/22/23 07:16 PM
05/22/23 07:16 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Oh Cab I'm so sorry brother. May she rest in peace and I know you find comfort in that. Sink yourself into Mopars and we are here for you brother.
Facts are stubborn things.
[Re: larrymopar360]
#3146256
05/22/23 07:58 PM
05/22/23 07:58 PM
Posts: 1,552 Michigan
Kiddart
Very Sorry for your loss Cab.
Prayers sent your way!!
Thank you Kiddart
[Re: CSK]
#3146263
05/22/23 08:20 PM
05/22/23 08:20 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I was thinking they used the same 6.4 thats in my Challenger, but I guess I was wrong, interesting Aren't they same 6.4, different exhaust manifolds? I believe that's the case on the 5.7 truck versus cars.
