Stock truck 6.4 motors, how much power and costs used from a #3098804
12/01/22 10:50 PM
12/01/22 10:50 PM
Cab_Burge Offline OP
I'm thinking about finding and buying a used 6.4 stick shift motor out of a wreck truck, how much torque and HP do they make stock, not a special order version tsk if they made them confused
I have 1967 Satellite two door hardtop that was strip by a junkyard of the drivetrain, front group and interior including the dash so I'm thinking it will make a good car for learning about the new hemi motors with a single carb on it for bracket racing luck help
I may consider trying to use the stock fuel injection on it if I can find a kit to convert it to an easy to use ECU kit that won't break my bank funds luck
All help and any comments on these motors and my intend use appreciated, THANKS in advance up
Cab
I Google those pickup motors and saw that the 2021 pick up motors are suppose to have 410 HP with 429 Ft. Lbs. torque, I didn't think to write the RPM down for either one blush shruggy
That should work okay to start with, learn first and then try hopping it up wrench devil
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3098984
12/02/22 04:21 PM
12/02/22 04:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I was thinking they used the same 6.4 thats in my Challenger, but I guess I was wrong, interesting
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3099057
12/02/22 07:31 PM
12/02/22 07:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My 2015 PowerWagon 6.4 is 410HP at 5,600 and 429 TQ at 4,000.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3099188
12/03/22 01:06 PM
12/03/22 01:06 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Cab I have looked at doing a hemi swap many times. You are in for at least 2k just for manifold/carb/ignition or a/m holley set up to run factory fuel ignition.
If it is a newer engine with the active runner intake you would be giving up too much power to go to a carb set up imo.
There is nothing cheap about a hemi retrofit. If and when Holley comes out with a controller that will handle the 8spd trans as well then I will likely take the plunge.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: mgoblue9798] #3099276
12/03/22 05:59 PM
12/03/22 05:59 PM
houston texas
gremlinsteve Offline
houston texas
Sound German auto has the 8 speed controller available
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: gremlinsteve] #3099333
12/03/22 09:42 PM
12/03/22 09:42 PM
okla.
sam64 Offline
sam64  Offline
okla.
Yes they do and their instructions are very vague to say the least! They expect you to be a tuner if you buy this. Edelbrock has a system that is a little better for the engine side than Holley. Pro Flo 4 Plus, it does not control MDS but does variable valve timing and short runner intake and alternator control.I have the Edelbrock on a 2017 5.7 in a 1968 D 100 SWB and it will will flat run !
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: sam64] #3099637
12/04/22 09:36 PM
12/04/22 09:36 PM
New York
64 Sportfury Offline
New York
I am curious why your opinion of the Pro Flo Plus is better than the Holley. Holley does have a controller for the 46RE trans. It does not handle the alternator as you mentioned. I have the Pro Flo 4 on a 390 stroker and had quite a few problems getting it running. Ultimately they replaced all 8 injectors after making me jump through lots of their suggestions. I realized it was an injector issue when she would fire briefly after pouring fuel into the throttle body, Their techs wouldn't believe this was the case. I have had a few other issues that kept me from using Edelbrock for my 6.4 Hemi swap. I went with the Holley as they have nearly all supporing parts for the swap (B body wagon). This tells me Holley has invested significantly more than Edelbrock. The alternator issue however, is annoying but not insurmountable.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3099842
12/05/22 03:29 PM
12/05/22 03:29 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
No stick shift 6.4s that I am aware of. That said why would it matter?
410 HP bone stock, put in good headers when you do a swap and tune whatever system you run to control it and you should make minimum 450 HP unless you go to a very crappy intake like the low rise mopar single plane.
Whatever controls your existing alternator will control the factory one on the hemi, it is just a denso and the field is manipulated just like it was in the old cars to maintain a certain voltage. Yes it would be nice to have it all in one but it is not a big deal.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: HotRodDave] #3100199
12/06/22 06:51 PM
12/06/22 06:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: gremlinsteve] #3100287
12/07/22 12:20 AM
12/07/22 12:20 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
They do but it is a cool grand. Not going to pay that on top of the cost of the Holley Term X or other a/m hemi control. Maybe someone will come out with a simple swap using factory computers soon that doesn't cost and arm and a leg.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: cudadoug] #3100450
12/07/22 03:40 PM
12/07/22 03:40 PM
Kalispell Mt.
Kalispell Mt.
Originally Posted by cudadoug
They made 361 HP and the power was still climbing rapidly when they shut it down, they had seafoam in the oil when they did it and a severly mismatched intake that would only start working at the RPM they stopped at. In my opinion that was a pretty pointless test, a stock 5.7 makes more with less CID, inferior heads, and smaller cam.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3106135
12/28/22 03:07 PM
12/28/22 03:07 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Came across this older article on the Motor Trend site. Gives a pretty good explanation on the 6.4 truck motor and how to make power for a swap.
https://www.motortrend.com/features/build-practical-bomb-proof-6-4l-hemi/
1972 Dodge Challenger
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: PLUM_72] #3146180
05/22/23 01:34 PM
05/22/23 01:34 PM
Update, my wife died Friday morning after fighting lung cancer for the last three years, may she now rest in peace bowwhiney
I'll probably start looking next week for a core motor after her funeral luck
I'm hoping that by keeping busy on projects I won't focus as much on her being gone luck
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3146205
05/22/23 03:01 PM
05/22/23 03:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Very sorry for your loss !!!!!!!
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: Cab_Burge] #3146218
05/22/23 05:07 PM
05/22/23 05:07 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Sorry Cab. My deepest condolences
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: A990] #3146237
05/22/23 06:43 PM
05/22/23 06:43 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Sorry 4 loss
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: moparjim79] #3146244
05/22/23 07:16 PM
05/22/23 07:16 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Oh Cab I'm so sorry brother. May she rest in peace and I know you find comfort in that. Sink yourself into Mopars and we are here for you brother.
Facts are stubborn things.
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: larrymopar360] #3146256
05/22/23 07:58 PM
05/22/23 07:58 PM
K
Kiddart Offline
Kiddart  Offline
K
Very Sorry for your loss Cab.
Prayers sent your way!!
Thank you
Kiddart
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: moparjim79] #3146260
05/22/23 08:10 PM
05/22/23 08:10 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Re: Stock truck 6.4 motors, how much power and costs used from a [Re: CSK] #3146263
05/22/23 08:20 PM
05/22/23 08:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Aren't they same 6.4, different exhaust manifolds? I believe that's the case on the 5.7 truck versus cars.
