Finally DONE! What will it run?!?!?
#3142436
05/04/23 08:19 AM
05/04/23 08:19 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well after about a year and a half of work, my '62 is finally converted over from the old small block turbo combo and ready to run.
I have had so much help from so many people, but more than anyone my Dad (dvw) has just put in HUNDREDS of hours into this car. No doubt I would have eventually gotten it done, but no where near the quality and craftsmanship level he brought to the project. Not to mention the hours my Mom put in helping on the interior, giving up time with my Dad, and keeping us alive!
HardcoreB built a hell of a motor for the combo too, and went above and beyond the original commissioned engine build he took on.
So here is the combo, and the obligatory moparts question for any new build.... what will it run?
3570lbs with driver ready for the starting line (heavier than I was hoping!) 4.10 Dana with Caltracs, 29.5 x 10.5 Pro Bracket Radials, and Mencer Double Adjustable Afco's 727 with good strong parts and Aluminum Drum. TA 8" converter spec'd for the combo (target 6200 stall)
486" Low Deck (4.385" bore x 4" stroke) Indy SR Heads, w/ 2.25" ti valves (flow 360cfm?) 275@.050 / .762" Lift Roller Cam, T&D 1.6 rockers, with PAC Springs Crower Ultra light crank, BME Aluminum Rods, with flat top pistons (12.2:1 compression) Hooker 2-1/8" headers with 3.5" collector Mod Man intake (which we named the SeanMan after the heavy runner length/porting/design changes of HardcoreB's work.) Two 750 AFB's Electric water pump & Vacuum pump pulling 10~12"
Re: Finally DONE! What will it run?!?!?
[Re: dizuster]
#3142437
05/04/23 08:21 AM
05/04/23 08:21 AM
dizuster
Oakland, MI
Really happy with the interior.
[Re: dizuster]
#3142444
05/04/23 08:44 AM
05/04/23 08:44 AM
Posts: 10,039 MN
JERICOGTX
MN
By the way the engine sounds, it will run 9.90's, but I think the 4.10's might slow it down some, and need a 4.56 rear gear. Just My opinion. I think 10.25's are reasonable.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3142457
05/04/23 09:39 AM
05/04/23 09:39 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No really good at these guessing games but I’m sure it will run great. Nice job guys. Now go have fun.
[Re: pittsburghracer]
#3142464
05/04/23 10:11 AM
05/04/23 10:11 AM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
Thinking 9.80's at Lapeer or Martin, and 10.20's at Milan if you go on a night when they aren't radial prepping. The car looks outstanding, love the interior and patina!
#3142466
05/04/23 10:13 AM
05/04/23 10:13 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Awesome job! I'm gonna say 9.70s-9.80s.
[Re: gregsdart]
#3142477
05/04/23 11:13 AM
05/04/23 11:13 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
No idea what it will run but certainly looks awesome. Nicely done.
[Re: gregsdart]
#3142479
05/04/23 11:19 AM
05/04/23 11:19 AM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
I'm going to guess 9.70's @ around 136 for the first outing, then you guys will continue to drop from there.... probably a 9.50 or better in it before the year is over.
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: dizuster]
#3142517
05/04/23 02:18 PM
05/04/23 02:18 PM
Posts: 1,552 Michigan
Kiddart
you guys do great stuff, you looking to adopt a brother or a son???
I cant wait to hear how it runs.
Thank you Kiddart
[Re: Cab_Burge]
#3142550
05/04/23 07:05 PM
05/04/23 07:05 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I've thought about building a 4.0 stroke B/RB stroker motor but haven't built one yet , maybe next year I've built more than one 3.91 stroke B and Rb motors and 4.150, 4.250, 4.320 and several 4.375 strokers with stock Mopar rod jourmnal sizes, never again using the 2.375 rod journal diameter by choice What made you decide to use that stroke? I'm thinking that combination will like RPM i Cab, years ago i built a 475 cube rb motor out of a stock crank cut to 2.10 sbc size at 4.0 inch, using a BME 396 aluminum custom rod. It worked great for what it was. The rod was 7.10 long, which fit some stroker pistons i had from a motor that broke a crank. The 2.10 bearings held up well, and the second owner got a lot of life out of it
[Re: gregsdart]
#3142560
05/04/23 07:48 PM
05/04/23 07:48 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
I've thought about building a 4.0 stroke B/RB stroker motor but haven't built one yet , maybe next year I've built more than one 3.91 stroke B and Rb motors and 4.150, 4.250, 4.320 and several 4.375 strokers with stock Mopar rod jourmnal sizes, never again using the 2.375 rod journal diameter by choice What made you decide to use that stroke? I'm thinking that combination will like RPM i Cab, years ago i built a 475 cube rb motor out of a stock crank cut to 2.10 sbc size at 4.0 inch, using a BME 396 aluminum custom rod. It worked great for what it was. The rod was 7.10 long, which fit some stroker pistons i had from a motor that broke a crank. The 2.10 bearings held up well, and the second owner got a lot of life out of it Thanks
[Re: dizuster]
#3142581
05/04/23 09:22 PM
05/04/23 09:22 PM
Posts: 6,340 Heaven
EvilB1Dart
Heaven
That's another one of the cool cars on here. I bet its going to run 9.80's.......but I think it's going to want 4.56's back there.
"Any fool can know. The point is to understand"
- A. Einstein
