1970 Charger OEM Disc Brake Caliper Location #3142160
05/03/23 03:57 AM
05/03/23 03:57 AM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Redoing my 70 Charger and not sure if the calipers should go on the front side of the rotor or rear of the rotor. I have everything together and am now second guessing things. I pulled the service manual to check something and it looks like they show the caliper to the rear of rotor (passenger side caliper is closer to the door). I have it back together the opposite (passenger side caliper to closer to front bumper).
Does anyone have any pictures of some that they are certain are the factory set up? I already googled a bunch of pictures and some are showing each way but all I have found are aftermarket and then seen a couple of restored pictures and it looks like they are using A Body style with the sliders on them. I do have some pictures of an all original 71 satellite I parted and they are showing to the front like I have mine put back together but I do not have any pictures of a 70 B Body. Looking at old pictures of my car it looks like the calipers are in the front but the Crager ss wheels are on it and i'm not positive.
Thanks for any help, again I have done several searches and can't find anything original. Hope I am explaining it the right way.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 70X] #3142164
05/03/23 06:21 AM
05/03/23 06:21 AM
Mass
charge70 Offline
charge70  Offline
Mass
They go to the front,
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: charge70] #3142207
05/03/23 09:50 AM
05/03/23 09:50 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
They go towards the rear.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 70X] #3142250
05/03/23 11:53 AM
05/03/23 11:53 AM
central il.
second 70 Offline
second 70  Offline
central il.
Front 70 Cuda. Also hiding place for my MSD coil. Lol
My calipers are 70 but the disc are the later bigger bearing hubs.
Mike
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: second 70] #3142256
05/03/23 12:14 PM
05/03/23 12:14 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Front. Part of the reason why the sway bar was redesigned was to make room for the single piston caliper.
Angry white pureblood male
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: ruderunner] #3142282
05/03/23 01:37 PM
05/03/23 01:37 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
This! Front side
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 70X] #3142340
05/03/23 05:13 PM
05/03/23 05:13 PM
Swapping the spindles so the calipers mount behind the spindles moves that weight to the rear which help the cars I've done that on stop and corner better. The skinny front drag tires didn't lock up as easy after moving them shruggy
it's your choice, show or go?
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: Cab_Burge] #3142406
05/03/23 11:42 PM
05/03/23 11:42 PM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Thanks so much guys, I appreciate it. Glad I don't have to take it all back apart.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 6PKRTSE] #3142440
05/04/23 08:33 AM
05/04/23 08:33 AM
N
NITROUSN Offline
NITROUSN  Offline
N
The 70 Charger FSM shows them mounted to the rear.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: NITROUSN] #3142448
05/04/23 08:58 AM
05/04/23 08:58 AM
VA
dragon slayer Offline
VA
70-72 KH Single piston was B and E body. So assuming that these are original they would be front mounted, but not sure how they could even be mounted in the rear. Spindles and Calipers were Right/Left specific.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: dragon slayer] #3142452
05/04/23 09:15 AM
05/04/23 09:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I can only state what the FSM shows. Was 69 disc to the rear? Could there be an up to and after build? Parts manual may clear this up.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: NITROUSN] #3142484
05/04/23 11:45 AM
05/04/23 11:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
69 down calipers were to the rear , 70 they moved to the front .
The spindles are not side specific as far as I know ... but I don't know everything shruggy
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 70X] #3142485
05/04/23 11:47 AM
05/04/23 11:47 AM
IMGTX Offline
IMGTX  Offline
I can not say for sure front or back because from an engineering standpoint they are the same.
BUT
I can tell you that the brake hoses will only work one way.
If you mount the caliper and and hose, when turning the tire side to side it will be obvious if the hose is in it's natural position or overly stretched/kinked.
Make sure you mount the calipers with the bleeder up top.
That is how I have determined it when building a car from a box of parts.
Hope it helps.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: JohnRR] #3142509
05/04/23 01:55 PM
05/04/23 01:55 PM
i think Mopar switch disc brakes in mid year 1969 on their B Bodies from the 4 piston Kelsey Hayes to the later larger single piston disc brakes confused shruggy
I did a frame off restoration on a 1969 Charger 500 in the mid to late 1980s for a lady who husband I had done some work for before he was killed in a road racing accident, I believe all of those cars (1969 Charger 500) were bult in late 1968 before Christmas, the 1969 Charger Daytona 500 were built after that..
My message is I think that car had the early K.H 4 piston disc brakes, but that was a long time ago and I may be mixing up memory as I had a early production 1970 Charger R/T V code car that i was working on back then also shruggy work
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: Cab_Burge] #3142569
05/04/23 08:05 PM
05/04/23 08:05 PM
VA
VA
Cab your way off. Not sure why necessary to post to a thread when you're just guessing. 67-69 B bodies and your 69 Charger 500 where BENDIX 4 caliper. The KH 4 piston were A body. No mid year change. 67-69 B body Bendix with 11.02" rotor. The whole set up of spindles and calipers and rotors are different in 70-72. No mix or match of parts. 70 B &E started the KH single piston with 10.98" rotors.
Yes the parts are side specific except rotors. Caliper brackets, Calipers to position bleed/hose in correct spot and spindles. Think about it. If you move the driver spindle with caliper forward to the passenger side the caliper winds up in the rear.
The 67-69 system seemed to be limited in production and part support. By the mid 90s rotors were not available. I am sure a lot of the early cars had a mismatch of parts installed trying to get them driveable if the original rotors were shot. Even today, you can only buy a rotor disc and must salvage a hub to restore the 6-69 Bendix system. Front is correct for OEM 70-72 B body.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: dragon slayer] #3142625
05/05/23 05:53 AM
05/05/23 05:53 AM
ohio
ohio
My 69 Roadrunner had 4 piston disc mounted to front. I changed to the big rotors and single piston.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: ruderunner] #3142739
05/05/23 09:00 PM
05/05/23 09:00 PM
N
NITROUSN Offline
NITROUSN  Offline
N
69 Is to the rear. FSM clearly states the Bendix and KH are mounted to the rear of the steering axis. FSM illustrates it also. Parts manual also shows it. 69 also had a short steel brake line from the hose to the caliper. 70 went to the front and the hose screwed directly into the caliper.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: NITROUSN] #3142957
05/07/23 04:04 AM
05/07/23 04:04 AM
Missouri
70X Offline OP
70X  Offline OP
Missouri
I know, that's why I asked the question. I'm leaving them in the front. Thanks for all of your help guys!
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: 70X] #3142963
05/07/23 06:04 AM
05/07/23 06:04 AM
ohio
ohio
Let me throw this out there, where does the hard line come to? Ahead or behind the knuckle?.
My understanding is the hose should cross the steering axis, so hard line at back means caliper to front and vice versa.
Re: 1970 Charger OEM Disc Brake Caliper Location [Re: ruderunner] #3142982
05/07/23 09:04 AM
05/07/23 09:04 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Front of knuckle has hose screwed into the caliper.
Rear of knuckle has a short steel line between the hose and the caliper.
I posted differences in the hoses above.
