Exhaust manifolds for Turbo A Body #3129838
03/16/23 10:11 AM
03/16/23 10:11 AM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Is there any exhaust manifolds that can be turned backwards in an A body with a 6.4L? If I understand right the bolt pattern will need to be re-drilled but I am OK with that.
Ideally I want to move forward and work on a turbo 5.7 or 6.4(preferably) combo for my 68 Barracuda over the next year or more.
Thank you for any information.
68 Barracuda Formula S 340
Re: Exhaust manifolds for Turbo A Body [Re: Bad340fish] #3129925
03/16/23 02:40 PM
03/16/23 02:40 PM
K
Kiddart Offline
Kiddart  Offline
K
if not mistaken i think it is one or two holes per side not that crazy to do. my son investigated a few years ago.
Thank you
Kiddart
Re: Exhaust manifolds for Turbo A Body [Re: Bad340fish] #3130791
03/20/23 11:59 AM
03/20/23 11:59 AM
The NB Vermont
dustaboy74 Offline
dustaboy74  Offline
The NB Vermont
Some people have use the jeep srt exhaust manifolds. You will need to redrill the heads and I used the Lisle exhaust manifold bolt fixture drilling them as it helped align all the holes and get proper depth of them. Was simple and easy to do and I am running the hooker log manifolds flipped forwards. Holley makes some of their blackheart headers that would work well for turbos too.
Re: Exhaust manifolds for Turbo A Body [Re: dustaboy74] #3131829
03/23/23 11:49 PM
03/23/23 11:49 PM
IL
furious70 Offline
furious70  Offline
IL
truck manifolds exit almost straight out and would be an option if you drill the 2 holes you need, especially if doing twins. I explored that but for a single turbo in my coronet and then the downpipe down low under the manifold with a oil filter relocation kit and a truck style accessory drive. 4" downpipe was tough though. If you didn't mind wrapping twin downpipes under the K member it'd be easy.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Exhaust manifolds for Turbo A Body [Re: furious70] #3140263
04/23/23 11:13 PM
04/23/23 11:13 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
A Guy on Facebook used a set of truck manifolds flipped forward. All he did was weld flanges on the end. But yes I think you have to redrill the center exhaust mount holes. Here is a picture of the turbo/ exhaust mounted in his 71/72 Dodge Dart
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Exhaust manifolds for Turbo A Body [Re: mopar65] #3140408
04/24/23 03:27 PM
04/24/23 03:27 PM
What about swapping the heads from side to side? Is that even possible on those motors and heads confused shruggy
Re: Exhaust manifolds for Turbo A Body [Re: Cab_Burge] #3140531
04/24/23 11:47 PM
04/24/23 11:47 PM
IL
furious70 Offline
furious70  Offline
IL
they are specific side to side but I'm not sure of all the reasons why
70 Sport Fury
68 Charger
69 Coronet
72 RR
