Exhaust manifolds for Turbo A Body
#3129838
03/16/23 10:11 AM
03/16/23 10:11 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Is there any exhaust manifolds that can be turned backwards in an A body with a 6.4L? If I understand right the bolt pattern will need to be re-drilled but I am OK with that.
Ideally I want to move forward and work on a turbo 5.7 or 6.4(preferably) combo for my 68 Barracuda over the next year or more.
Thank you for any information.
68 Barracuda Formula S 340
Re: Exhaust manifolds for Turbo A Body
[Re: Bad340fish]
#3129925
03/16/23 02:40 PM
03/16/23 02:40 PM
Posts: 1,547 Michigan
Kiddart
if not mistaken i think it is one or two holes per side not that crazy to do. my son investigated a few years ago.
Thank you Kiddart
[Re: dustaboy74]
#3131829
03/23/23 11:49 PM
03/23/23 11:49 PM
Posts: 2,254 IL
furious70
IL
truck manifolds exit almost straight out and would be an option if you drill the 2 holes you need, especially if doing twins. I explored that but for a single turbo in my coronet and then the downpipe down low under the manifold with a oil filter relocation kit and a truck style accessory drive. 4" downpipe was tough though. If you didn't mind wrapping twin downpipes under the K member it'd be easy.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#3140263
04/23/23 11:13 PM
04/23/23 11:13 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
A Guy on Facebook used a set of truck manifolds flipped forward. All he did was weld flanges on the end. But yes I think you have to redrill the center exhaust mount holes. Here is a picture of the turbo/ exhaust mounted in his 71/72 Dodge Dart
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Cab_Burge]
#3140531
04/24/23 11:47 PM
04/24/23 11:47 PM
Posts: 2,254 IL
furious70
IL
they are specific side to side but I'm not sure of all the reasons why
