Re: EFI Six-Pack - F&B ? [Re: Bruce K Bridges] #312645
02/26/11 12:57 PM
02/26/11 12:57 PM
cataclysm80 Offline
cataclysm80  Offline
The pricing is a bear as you're selling three complete throttlebodies as well as a fully ported manifold etc. etc. Come to the Mopars at the Strip show (or Spring Fling) and well talk about "show special pricing" if youd like!
Good to see you here Bruce! Thanks for the AC info!
Actually, I think your pricing is pretty decent if compared to the cost of buying a new stock six pack setup. Your setup costs a little more, but I feel it's worth it for the reliability of fuel injection + increased flow rates and WOW factor. I look forward to owning one of your setups someday. Thanks for giving us such a great product.
Tav
Re: EFI Six-Pack - F&B ? [Re: cataclysm80] #312646
02/28/11 04:27 PM
02/28/11 04:27 PM
San Diego CA
Bruce K Bridges Offline
San Diego CA
Why thanks!
6bbl MPI is a lot of fun to drive! I took a look at some of the previous postings on this topic. The whole reason for running a six barrel intake is to take advantage of the long runner, high velocity central throttle body flow path at low rpm and the short runner, high volumetric flow of the two outer bodies at high rpm. Youve got to have a progressive linkage to make this happen. No amount of tuning the EFi system will "simulate" this fluid dynamic effect. That is why most every new car with a gas motorhas a variable runner intake tract that adjusts the lengths of the intake runners as the RPM/load/etc increases. The beauty thing is I dont need to worry about losing my atomization in the manifold (ported to 48mm +) or maintaining a high vacuum signal to keep the outers from flopping around. Big displacement, big heads and or cams, etc all work with the 6bbl MPI system and you get designed-in tip-in control without any histrionics. Try running a 2000 cfm single blade TB to learn true right foot control... Geeze.. turned into a plug for sixpacks!
Now I need to drive...
Bruce
I sell fuel injection, but Ill still rebuild your carb if I have to...
Re: EFI Six-Pack - F&B ? [Re: Bruce K Bridges] #312647
07/07/11 01:15 AM
07/07/11 01:15 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
Bruce - I received my EFI 6 pac from Rocket, it is a work of art! The engine is still at the machine shop, so I havent been able to mock it up yet (still lots of other stuff to attend too). I am looking forward to driving the car with this intake system. thanks for producing a great product.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: EFI Six-Pack - F&B ? [Re: 70chall440] #312648
07/22/11 07:33 PM
07/22/11 07:33 PM
San Diego CA
San Diego CA
Excellent and thank you!
If you or Rocket have any questions, please contact me! Id also like to get some pics and a description of your ride when its done!
Bruce
Re: EFI Six-Pack - F&B ? [Re: Mopar_Rich] #312649
07/22/11 08:59 PM
07/22/11 08:59 PM
Canada
CrAzYMoPaRGuY Offline
Canada
You get the manifold from Bruce at F&B. That includes all the throttle bodies, IAC (idle air control), TPS (throttle position sensor), injectors (size depends on your HP level), linkage etc.
I supply you with all the electronics:
ECU (with O2 sensor), dual-sync distributor (for full sequential operation), harness, Sensors: CTS (coolant temp), ATS (air temp), map (manifold vacuum), Laptop software, a base program, tech support.
You would also need an EFI fuel system which requires an EFI pump (45 PSI), an EFI regulator, and a return line to the tank. I can supply all these components too or make suggestions.
Is the dual sync distributor you sell the same as the Accel dual sync distributor?
And Bruce.... I bet one benefit of the EFI on your Interceptor would be it would probably be superior for all out cornering on a road course.... I say this because my Interceptor has two Edelbrock 500s, runs great in a straight line, runs great through the bends, but I have put it into long corners in a violent way and in certain conditions towards the end of a long corner it sometimes seems to flood/stumble.... if I try driving like I stole it that is....
Beautiful Interceptor Bruce!
CrAzYMoPaRGuY
Re: EFI Six-Pack - F&B ? [Re: CrAzYMoPaRGuY] #312650
07/23/11 09:54 AM
07/23/11 09:54 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No. Fast has their own dual-sync, but you can use one from Accel too with a minor mod that I describe on my web site.
And EFI does solve the "rock crawler, road racer" problem.
Re: EFI Six-Pack - F&B ? [Re: Mopar_Rich] #312651
07/23/11 09:21 PM
07/23/11 09:21 PM
Canada
Canada
Would it benefit me to swap to the latest FAST system over my Accel gen7 DFI? I have a wideband and dual sync distributor, injectors, Aeromotive fuel system, all my sensors etc....
Is the latest FAST ecu better than an Accel gen7?
CrAzYMoPaRGuY
Re: EFI Six-Pack - F&B ? [Re: CrAzYMoPaRGuY] #312652
07/23/11 09:34 PM
07/23/11 09:34 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No not really. Accel and FAST have been duking it out for years and they are both very competitive. What one system adds - the other system adds too. Sure there are things I like about FAST but it's not worth the $ if you already have DFI.
Re: EFI Six-Pack - F&B ? [Re: Mopar_Rich] #312653
07/23/11 10:56 PM
07/23/11 10:56 PM
Canada
Canada
Thanks!!
CrAzYMoPaRGuY
Re: EFI Six-Pack - F&B ? [Re: Bruce K Bridges] #312654
07/25/11 12:35 PM
07/25/11 12:35 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
Bruce
no problem. The car is still in the mock up stage and the engine is at the machine shop. Once I get the engine put together, I wil post some pics here and send them to you (if you like).
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: EFI Six-Pack - F&B ? [Re: 70chall440] #312655
07/25/11 12:43 PM
07/25/11 12:43 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
To anyone thinking about going this route, I will say up front that what you get far exceeds your expectations. The package will amaze you. Bruce is not only a professional, but a dedicated Mopar lover. He knows what he is talking about and super helpful. I would highly recommend F&B to anyone wanting to include EFI onto thier project. I will be using it for a roadrace/autoX AAR Cuda clone and selected it after talking to Bruce and completing a lot of research. I can't speak highly enough of F&B.
Thanks for making a beautiful, awesome product.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: EFI Six-Pack - F&B ? [Re: 70chall440] #312656
09/12/11 12:35 AM
09/12/11 12:35 AM
moscow mills mo
smracing Offline
smracing  Offline
moscow mills mo
how did you plan come out
looking at doing 440 6 pack injected
cuda clone have a carb system now
looking to up grade
mild build
all info helpful thanks
Mike
Re: EFI Six-Pack - F&B ? [Re: smracing] #312657
09/13/11 08:58 PM
09/13/11 08:58 PM
San Diego CA
San Diego CA
My ears were burning!
Thanks Rocket resto for the kudos! Wait until you drive it, then it will really shine! All the six pack fun and performance without a wet manifold. No distribution problems (fuel is metered to the valves by the injectors) Feel free to call or email or PM with any questions.
Thanks!
Bruce
Re: EFI Six-Pack - F&B ? [Re: Bruce K Bridges] #312658
09/14/11 12:53 AM
09/14/11 12:53 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Bruce
That is one great looking install. And the a/c is a great touch. By the way Bouchillon sp? now makes a low mount (under the alternator) a/c compressor for the B/RB engine.
I was thinking the Indy Mod Man Intake with the sixpack top would make a good efi intake like this? But now it looks like the standard intake is working well.
Re: EFI Six-Pack - F&B ? [Re: PHJ426] #312659
06/12/13 03:57 PM
06/12/13 03:57 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
this is awesome system but not without some issues that have to be overcome. Things like routing the wiring, locating and installing the fuel pump and wiring it all up will take some time and thought. That said, it is a beautiful system.
I would highly recommend that anyone contemplating this read up on EFI systems if they don't have a good working knowledge of them already. It will greatly help you understand what everything does and where it should go.
I will say that if you intend to purchase this system and want to mount the computer inside the car, you need to know that it will take a fairly decent sized hole in the firewall to get all of the wires through to the intake and engine compartment.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: EFI Six-Pack - F&B ? [Re: 70chall440] #312660
06/12/13 05:22 PM
06/12/13 05:22 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
is the car together and running ?
Pictures
Re: EFI Six-Pack - F&B ? [Re: JohnRR] #312661
06/13/13 12:59 AM
06/13/13 12:59 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
unfortunately not, I was "distracted" by my 52 B3B Hemi build and my 98 Diesel 3500 repair as well as work. As soon as I get the 52 back together then I will be back to the Cuda. I got hung up in the wiring and lost some steam.
Here are some pictures of where I am with it.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: EFI Six-Pack - F&B ? [Re: 70chall440] #312662
06/13/13 01:01 AM
06/13/13 01:01 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
Here is another
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
