What’s a driveshaft costing these days #3123542
02/21/23 11:02 PM
02/21/23 11:02 PM
houston texas
gremlinsteve Offline OP
houston texas
Needing to have one built and I’m wondering what it’s costing to have one built
These days. I’m located in houston if that matters
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: What’s a driveshaft costing these days [Re: gremlinsteve] #3123602
02/22/23 09:38 AM
02/22/23 09:38 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just contact Cass (doctordiff) and he will hook you up up
https://www.doctordiff.com/strange-engineering-driveshaft.html
Gus beer
64 Plymouth Savoy
Dana 60
Re: What’s a driveshaft costing these days [Re: gremlinsteve] #3123630
02/22/23 11:30 AM
02/22/23 11:30 AM
maryland
mhead Offline
mhead  Offline
maryland
I had an aluminum one made from driveshaft specialties in Texas.I have no complaints with it.
Also check out Mark Williams site about drive shaft critical speed.
Re: What’s a driveshaft costing these days [Re: gremlinsteve] #3123636
02/22/23 11:42 AM
02/22/23 11:42 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I had a long one shortened, end welded back in & balanced last year. Local shop did it for under $100.00
Re: What’s a driveshaft costing these days [Re: Alaskan_TA] #3123646
02/22/23 12:10 PM
02/22/23 12:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Basic street stuff around here ran about $175 a couple years ago.
I use a guy about 50 miles from me who does really nice work, checks everything.
God only knows what $hipping would be.
There are always ads in Natl Dragster for the race stuff, but I don't get ND any more.
Re: What’s a driveshaft costing these days [Re: topside] #3123694
02/22/23 02:57 PM
02/22/23 02:57 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Used a local shop to build me a new one after the big block swap. Built to spec with everything new (slip yoke included) was $350.
Re: What’s a driveshaft costing these days [Re: MarkZ] #3123698
02/22/23 03:15 PM
02/22/23 03:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid had his done by Dennys large yokes and ears ago.Cost was IIRC 300 or 350.That thing was beat and ran hard and never a problem
Chrysler Firepower
Re: What’s a driveshaft costing these days [Re: MarkZ] #3123699
02/22/23 03:17 PM
02/22/23 03:17 PM
K
Kiddart Offline
Kiddart  Offline
K
Mark Z
can you share the shop name please? PM me if you like
Thank you
Kiddart
Re: What’s a driveshaft costing these days [Re: Alaskan_TA] #3123731
02/22/23 04:29 PM
02/22/23 04:29 PM
moparx Offline
moparx  Offline
any idea what speed it was balanced at ?
a buddy had one done locally from a truck place, and always had a vibration problem with it. i can't remember what rpm it was balanced at, but it was pretty low.
the shaft was in a 55 chevy with 4.10's and a 700R4 od, and it vibrated pretty good at certain speeds. we checked runout, and it was right at the limit [in my opinion] at around .018 or so.
i tried to get him to have it high speed balanced, but someone wanted the car and threw good money at him before he had a chance to try that.
beer
Re: What’s a driveshaft costing these days [Re: moparx] #3123794
02/22/23 07:36 PM
02/22/23 07:36 PM
houston texas
houston texas
Well I spoke with my local shop today
Going to run 350
I’m happy with that
Re: What’s a driveshaft costing these days [Re: moparx] #3123795
02/22/23 07:38 PM
02/22/23 07:38 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I had one made in April of 2022 to these specs:
Strange Engineering 1350 Driveshaft Assembly
Options: Application: 3" Street/Strip (U1699) , Transmission: 727 Automatic 29 Spline , Add Forged Steel 1350 Pinion Yoke
It costed me $424 - purchased through Dr. Diff. Easy Transaction. Would recommend.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: What’s a driveshaft costing these days [Re: Kiddart] #3123819
02/22/23 08:34 PM
02/22/23 08:34 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by Kiddart
Mark Z
Same here please.
Re: What’s a driveshaft costing these days [Re: Kiddart] #3123893
02/23/23 02:06 AM
02/23/23 02:06 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Mark Z
CCI Driveline in Casco, Michigan.
https://www.ccidriveline.com/
Had it built in either 2019 or 2020.
Re: What’s a driveshaft costing these days [Re: MarkZ] #3126241
03/03/23 08:10 PM
03/03/23 08:10 PM
houston texas
houston texas
Well
Got the driveshaft made and gearvendors installed
The truck runs well and the shift into od is firm with no issues
