thick carb base gasket #3122265
02/17/23 10:32 AM
02/17/23 10:32 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Dose anybody know the best carb base gasket part number ? 1970 plymouth gtx carter 4737s carb.the fel-pro was junk
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: thick carb base gasket [Re: GTXKARL] #3122319
02/17/23 01:06 PM
02/17/23 01:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What happened to the felpro ?
Re: thick carb base gasket [Re: JohnRR] #3122361
02/17/23 03:34 PM
02/17/23 03:34 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I needed one last year for my 69 gtx with the carter and I found an edelbrock on the shelf of a local Autozone. Was thereabouts the same price as summit and was in my hand quicker. It was a fiber 3/8 style. Somebody had put a thin paper one and a thin metal “heat shield” on it and that stuff won’t cut it with todays gas. The vapor separator probably is what kept it running, but the fuel was boiling in the carb until I out that one on. The factory choke stat still worked without any adjustment.
I don’t have a part number handy, but it was a simple search that netted what I needed.
I want my fair share
Re: thick carb base gasket [Re: SomeCarGuy] #3122378
02/17/23 04:53 PM
02/17/23 04:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Same here
My local O'Reilly had it on the shelf
Re: thick carb base gasket [Re: JohnRR] #3122440
02/17/23 09:33 PM
02/17/23 09:33 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Before i even put it on it started peel apart .
Re: thick carb base gasket [Re: GTXKARL] #3122456
02/17/23 11:00 PM
02/17/23 11:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What material??? picture?
For heat insulation I prefer two thin compressible paper gaskets (normally grey in color) and a phenolic spacer. The thick paper/cardboard can lead to warped flanges twocents
Re: thick carb base gasket [Re: TJP] #3122495
02/18/23 10:51 AM
02/18/23 10:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said.
Re: thick carb base gasket [Re: JohnRR] #3122536
02/18/23 02:05 PM
02/18/23 02:05 PM
moparx Offline
moparx  Offline
at one time, i had some thick gaskets that were gray in color, plus had some plastic spacers in the bolt holes. they were supposed to keep one from over tightening the flanges.
i can't remember who made them.
beer
Re: thick carb base gasket [Re: moparx] #3122551
02/18/23 02:34 PM
02/18/23 02:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ yeah, that's the first thing that came to mind for me.
A light smear of bearing grease on either side and they're basically bulletproof.
Thick base gaskets in general haven't been hard to find.
Re: thick carb base gasket [Re: topside] #3122596
02/18/23 05:25 PM
02/18/23 05:25 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Yes this one
https://www.oreillyauto.com/detail/...harger?q=Edelbrock+base+gasket&pos=0
Next question would bee , is your intake manifold /4-hole / Divided / Open
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: thick carb base gasket [Re: bee1971] #3122601
02/18/23 05:42 PM
02/18/23 05:42 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by bee1971
Yes this one
That is damned pricey
Re: thick carb base gasket [Re: Sniper] #3122605
02/18/23 06:01 PM
02/18/23 06:01 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Yes this one
Yes
However they work great as a heat insulator for the Factory Carters and Edelbrocks also
I spray some silicone on both sides of the gasket before insulation - That way nothing sticks if you have to remove the carb for tuning
They have a divided base gasket also
Siberian Huskies
Re: thick carb base gasket [Re: bee1971] #3122607
02/18/23 06:06 PM
02/18/23 06:06 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Fel Pro for the factory Carter AVS
Thick depending upon year
https://www.oreillyauto.com/detail/...-charger?q=Fel-pro+base+gasket&pos=1
Siberian Huskies
Re: thick carb base gasket [Re: bee1971] #3122614
02/18/23 06:31 PM
02/18/23 06:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You can get that same gasket from Amazon about half price, free shipping. But since the OP wasn't happy with the Felpro gasket he has I didn't want to mention it. Comments on the part at Amazon say the metal spacers keep the carb from sealing properly. So you may want to pass on this one.
