thick carb base gasket
#3122265
02/17/23 10:32 AM
02/17/23 10:32 AM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Dose anybody know the best carb base gasket part number ? 1970 plymouth gtx carter 4737s carb.the fel-pro was junk
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: thick carb base gasket
[Re: GTXKARL]
#3122319
02/17/23 01:06 PM
02/17/23 01:06 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
What happened to the felpro ?
[Re: JohnRR]
#3122361
02/17/23 03:34 PM
02/17/23 03:34 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
I needed one last year for my 69 gtx with the carter and I found an edelbrock on the shelf of a local Autozone. Was thereabouts the same price as summit and was in my hand quicker. It was a fiber 3/8 style. Somebody had put a thin paper one and a thin metal “heat shield” on it and that stuff won’t cut it with todays gas. The vapor separator probably is what kept it running, but the fuel was boiling in the carb until I out that one on. The factory choke stat still worked without any adjustment.
I don’t have a part number handy, but it was a simple search that netted what I needed.
I want my fair share
[Re: SomeCarGuy]
#3122378
02/17/23 04:53 PM
02/17/23 04:53 PM
Posts: 21,451 It's a dry heat
gtx6970
It's a dry heat
I don’t have a part number handy, but it was a simple search that netted what I needed. Same here My local O'Reilly had it on the shelf
[Re: JohnRR]
#3122440
02/17/23 09:33 PM
02/17/23 09:33 PM
GTXKARL
Philadelphia, PA
What happened to the felpro ? Before i even put it on it started peel apart .
[Re: GTXKARL]
#3122456
02/17/23 11:00 PM
02/17/23 11:00 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
What happened to the felpro ? Before i even put it on it started peel apart . What material??? picture? For heat insulation I prefer two thin compressible paper gaskets (normally grey in color) and a phenolic spacer. The thick paper/cardboard can lead to warped flanges
[Re: TJP]
#3122495
02/18/23 10:51 AM
02/18/23 10:51 AM
JohnRR
U.S.S.A.
What happened to the felpro ? Before i even put it on it started peel apart . What material??? picture? For heat insulation I prefer two thin compressible paper gaskets (normally grey in color) and a phenolic spacer. The thick paper/cardboard can lead to warped flanges What he said.
[Re: Sniper]
#3122605
02/18/23 06:01 PM
02/18/23 06:01 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Yes However they work great as a heat insulator for the Factory Carters and Edelbrocks also I spray some silicone on both sides of the gasket before insulation - That way nothing sticks if you have to remove the carb for tuning They have a divided base gasket also
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#3122607
02/18/23 06:06 PM
02/18/23 06:06 PM
bee1971
Sobieski Wi
