What is this steering column from? #3112187
01/15/23 05:12 PM
01/15/23 05:12 PM
Alabama
baldjugglingogre Offline OP
Alabama
This steering column was left in the bathroom closet (!?) of my house when I purchased it. No way of contacting the previous owner. A quick google suggests early 70's Plymouth but I was hoping for more detail so that I can find it a home. Can anyone tell me more?
Pictures:
https://photos.app.goo.gl/2sp6K2KD43PKkifX6
Thanks in advance,
-Tim
Re: What is this steering column from? [Re: baldjugglingogre] #3112200
01/15/23 06:16 PM
01/15/23 06:16 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
70 E body.
will fit to 74.
the crush can is the same from 70-74.
no lock lever in 70. he lock release lever was started in 71-74
perception is 90% of reality
Re: What is this steering column from? [Re: Mr T2U] #3112201
01/15/23 06:19 PM
01/15/23 06:19 PM
GA
roadrunninMark Offline
GA
Can you tell if it is a power steering or manual steering column? I am looking for a manual steering column.
Re: What is this steering column from? [Re: roadrunninMark] #3112203
01/15/23 06:26 PM
01/15/23 06:26 PM
Alabama
Alabama
Do you know what to look for to determine that? I have no knowledge of this stuff.
-Tim
Re: What is this steering column from? [Re: roadrunninMark] #3112204
01/15/23 06:26 PM
01/15/23 06:26 PM
Mr T2U Offline
Mr T2U  Offline
couldn't tell you. it's been several years since i worked on E bodies.
the difference between the 2 is the steering shaft length on the lower column.
the column can be made to fit both by lengthening or shortening the collapsing steering shaft. there is a plastic pin that keeps this from sliding. just hit the shaft at the bottom end and this snaps the pin.
Re: What is this steering column from? [Re: Mr T2U] #3112215
01/15/23 07:00 PM
01/15/23 07:00 PM
Alabama
Alabama
Thanks for the info, Mr T2U!
-Tim
Re: What is this steering column from? [Re: baldjugglingogre] #3112234
01/15/23 07:51 PM
01/15/23 07:51 PM
Missouri
70X Offline
70X  Offline
Missouri
This looks like it has the lock lever to me.
Re: What is this steering column from? [Re: baldjugglingogre] #3112319
01/15/23 11:33 PM
01/15/23 11:33 PM
The inner shaft looks short like the power steering shafts did shruggy
Needs to be measured to be sure which one it is twocents
Re: What is this steering column from? [Re: Cab_Burge] #3112390
01/16/23 05:53 AM
01/16/23 05:53 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That’s a 71-74 ebody because of the locking lever right below the key slot. It looks like a power steering column to me. The steering adapter that connects the steering box is a different spline on power vs manual. The power is larger if my memory is correct. I’ve shorten a shaft as mentioned above, but that’s not the proper way. They make two different shafts. That collapsable column is so it won’t drive the rod through thee driver on impact. Maybe I need to move more often if people are going to leave ebody parts in the house when they leave!
Re: What is this steering column from? [Re: fastmark] #3112448
01/16/23 11:14 AM
01/16/23 11:14 AM
GA
GA
Mr.T, if you snap the pin and move it down, do you then need to put another pin in place to lock it in?
I'll measure my power column on the exposed inner shaft to the top of the coupling and report back. ** It appears to be about 9 1/4" from where it goes into the outer shaft to the top of the coupling.***
I would like a second column either way, I would like to keep my original column as is and have a second one to eventually do an electric steering conversion on.
Re: What is this steering column from? [Re: roadrunninMark] #3112663
01/16/23 08:01 PM
01/16/23 08:01 PM
Mr T2U Offline
Mr T2U  Offline
i just install it without replacing the pin.
the steering shaft will slide in and out easily and sometimes make installation a pain.
Re: What is this steering column from? [Re: Mr T2U] #3112674
01/16/23 08:26 PM
01/16/23 08:26 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
look like power steering
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: What is this steering column from? [Re: 1969gtx] #3112788
01/17/23 04:47 AM
01/17/23 04:47 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
By the courtesy light and hazzard knob , is a late 71 up to 74 column.
Re: What is this steering column from? [Re: Cab_Burge] #3112789
01/17/23 04:49 AM
01/17/23 04:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or measure the coupler hole diameter
Re: What is this steering column from? [Re: NachoRT74] #3112829
01/17/23 10:45 AM
01/17/23 10:45 AM
Alabama
Alabama
Assuming that the cylindrical metal tip is the coupler, the inner diameter is 0.6" and the outer diameter is 1.6" and the rectangular part is ~1.83" on the long side.
-Tim
Re: What is this steering column from? [Re: roadrunninMark] #3112832
01/17/23 10:49 AM
01/17/23 10:49 AM
Alabama
Alabama
The inner shaft measures just a hair over 10" from the top of the coupling to where it disappears into the outer shaft.
-Tim
Re: What is this steering column from? [Re: baldjugglingogre] #3112840
01/17/23 11:16 AM
01/17/23 11:16 AM
GA
GA
That sounds like a power steering column then. Mine measured about 9 1/4", so very close to yours (most likely the same as yours, just probably measuring a little differently than you). The manual column is a good couple inches longer (just looking at the adapter available). If you would like to sell it, send me a PM. I see you are in AL, I am in GA, just south of Atlanta.
