What is this steering column from?
#3112187
01/15/23 05:12 PM
01/15/23 05:12 PM
Posts: 5 Alabama
baldjugglingogre
Alabama
This steering column was left in the bathroom closet (!?) of my house when I purchased it. No way of contacting the previous owner. A quick google suggests early 70's Plymouth but I was hoping for more detail so that I can find it a home. Can anyone tell me more? Pictures: https://photos.app.goo.gl/2sp6K2KD43PKkifX6Thanks in advance,
-Tim
Re: What is this steering column from?
[Re: baldjugglingogre]
#3112200
01/15/23 06:16 PM
01/15/23 06:16 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
70 E body. will fit to 74. the crush can is the same from 70-74. no lock lever in 70. he lock release lever was started in 71-74
perception is 90% of reality
[Re: roadrunninMark]
#3112203
01/15/23 06:26 PM
01/15/23 06:26 PM
Posts: 5 Alabama
baldjugglingogre
Alabama
Do you know what to look for to determine that? I have no knowledge of this stuff.
-Tim
#3112204
01/15/23 06:26 PM
01/15/23 06:26 PM
Mr T2U
couldn't tell you. it's been several years since i worked on E bodies. the difference between the 2 is the steering shaft length on the lower column. the column can be made to fit both by lengthening or shortening the collapsing steering shaft. there is a plastic pin that keeps this from sliding. just hit the shaft at the bottom end and this snaps the pin.
[Re: fastmark]
#3112448
01/16/23 11:14 AM
01/16/23 11:14 AM
Posts: 2,941 GA
roadrunninMark
GA
Mr.T, if you snap the pin and move it down, do you then need to put another pin in place to lock it in?
I'll measure my power column on the exposed inner shaft to the top of the coupling and report back. ** It appears to be about 9 1/4" from where it goes into the outer shaft to the top of the coupling.***
I would like a second column either way, I would like to keep my original column as is and have a second one to eventually do an electric steering conversion on.
#3112663
01/16/23 08:01 PM
01/16/23 08:01 PM
Mr T2U
i just install it without replacing the pin. the steering shaft will slide in and out easily and sometimes make installation a pain.
[Re: Mr T2U]
#3112674
01/16/23 08:26 PM
01/16/23 08:26 PM
Posts: 643 southern conn
1969gtx
southern conn
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#3112788
01/17/23 04:47 AM
01/17/23 04:47 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
By the courtesy light and hazzard knob , is a late 71 up to 74 column.
[Re: Cab_Burge]
#3112789
01/17/23 04:49 AM
01/17/23 04:49 AM
NachoRT74
Valencia, España
The inner shaft looks short like the power steering shafts did Needs to be measured to be sure which one it is or measure the coupler hole diameter
[Re: NachoRT74]
#3112829
01/17/23 10:45 AM
01/17/23 10:45 AM
Posts: 5 Alabama
baldjugglingogre
Alabama
Assuming that the cylindrical metal tip is the coupler, the inner diameter is 0.6" and the outer diameter is 1.6" and the rectangular part is ~1.83" on the long side.
-Tim
#3112832
01/17/23 10:49 AM
01/17/23 10:49 AM
Posts: 5 Alabama
baldjugglingogre
Alabama
The inner shaft measures just a hair over 10" from the top of the coupling to where it disappears into the outer shaft.
-Tim
