Re: Barton rocker system
[Re: Dragula]
#3112807
01/17/23 08:44 AM
01/17/23 08:44 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
There is no required amount of shims. They include them so that you can adjust as needed for your application as mentioned above.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3112812
01/17/23 09:40 AM
01/17/23 09:40 AM
Posts: 12,409 Taxes & Virus's R-US, NY
Dragula
The springs are set to height. The roller tips on intake set dead center and the exhaust are very close to center. Thats all i can tell at this point til i get them bolted on and get more parts. Do you have .090" to .100" of clearance between the rocker arm and the outer edge of the spring? Then you should be ok...
[Re: mopar dave]
#3112842
01/17/23 11:22 AM
01/17/23 11:22 AM
Dragula
You can't change the rocker ratio, so the articulation remains the same as it follows the cam, so the shims can only be there to make sure the rocker arms sits high enough so they don't hit the outer edge of the springs when in motion...
You have probably seen a million sets of wedge rockers on here that hit the outer edge of the springs...Makes a mess of the aluminum rockers.
[Re: Dragula]
#3112859
01/17/23 12:32 PM
01/17/23 12:32 PM
Posts: 4,210 New York
polyspheric
New York
Centered is nice, but not important (unless the tip passes really close to the edge of the stem). 1. With the valve closed, the roller should be inside the center (close to the valley) 2. At 25% lift the roller is centered on the tip 3. At 50% lift the roller reaches its farthest point away from the valley, and stops 4, Reversing, 75% lift when centered again 5. Full lift returning to position 1
Boffin Emeritus
