Barton rocker system #3112762
01/17/23 12:02 AM
01/17/23 12:02 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Anyone set these rockers up before. They come with shims for the stands, but no directions as how many under each stand. The rollers look to sit centered on the valves.
Re: Barton rocker system [Re: mopar dave] #3112799
01/17/23 07:04 AM
01/17/23 07:04 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I guess that would depend on the wear pattern across the valve tip on how much shimming is required, Post some pics of the legendary rockers.
Re: Barton rocker system [Re: RATTRAP] #3112804
01/17/23 08:19 AM
01/17/23 08:19 AM
Mt Morris Michigan
Mt Morris Michigan
I don’t have a good pic at the moment. I don’t have the lifters and push rods yet, so I’ll just put the shims away til I do. It’s gonna be a couple yrs before I can finish this.
Re: Barton rocker system [Re: mopar dave] #3112805
01/17/23 08:39 AM
01/17/23 08:39 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am assuming once the springs are setup to their correct install height, the rocker shims are to get the rockers near to parallel to the top of the springs just as the rocker touches the tip of the valve when fully closed. You would not want to grind the rocker arm for spring clearance.
Re: Barton rocker system [Re: Dragula] #3112807
01/17/23 08:44 AM
01/17/23 08:44 AM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
There is no required amount of shims. They include them so that you can adjust as needed for your application as mentioned above.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Barton rocker system [Re: 6PKRTSE] #3112809
01/17/23 09:07 AM
01/17/23 09:07 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
penguin nice parts there
Re: Barton rocker system [Re: Dragula] #3112811
01/17/23 09:20 AM
01/17/23 09:20 AM
Mt Morris Michigan
Mt Morris Michigan
The springs are set to height. The roller tips on intake set dead center and the exhaust are very close to center. Thats all i can tell at this point til i get them bolted on and get more parts.
Re: Barton rocker system [Re: mopar dave] #3112812
01/17/23 09:40 AM
01/17/23 09:40 AM
Dragula Offline
Dragula  Offline
Do you have .090" to .100" of clearance between the rocker arm and the outer edge of the spring? Then you should be ok...
Re: Barton rocker system [Re: Dragula] #3112814
01/17/23 09:49 AM
01/17/23 09:49 AM
Mt Morris Michigan
Mt Morris Michigan
I will take a look. Thanks
Re: Barton rocker system [Re: mopar dave] #3112842
01/17/23 11:22 AM
01/17/23 11:22 AM
Dragula Offline
Dragula  Offline
You can't change the rocker ratio, so the articulation remains the same as it follows the cam, so the shims can only be there to make sure the rocker arms sits high enough so they don't hit the outer edge of the springs when in motion...
You have probably seen a million sets of wedge rockers on here that hit the outer edge of the springs...Makes a mess of the aluminum rockers.
Re: Barton rocker system [Re: Dragula] #3112859
01/17/23 12:32 PM
01/17/23 12:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Centered is nice, but not important (unless the tip passes really close to the edge of the stem).
1. With the valve closed, the roller should be inside the center (close to the valley)
2. At 25% lift the roller is centered on the tip
3. At 50% lift the roller reaches its farthest point away from the valley, and stops
4, Reversing, 75% lift when centered again
5. Full lift returning to position 1
Boffin Emeritus
Re: Barton rocker system [Re: polyspheric] #3112860
01/17/23 12:34 PM
01/17/23 12:34 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, well since i wont know that for a couple yrs, i thought being centered would be a good start.
