Re: Can't occupy the same space
[Re: Kudakidd]
#3110693
01/10/23 09:53 PM
01/10/23 09:53 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
A Holley carburetor and the stock coil location on a 440. Any ideas? CH4B will fix it.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Kudakidd]
#3110736
01/11/23 02:33 AM
01/11/23 02:33 AM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
A Holley carburetor and the stock coil location on a 440. Any ideas? I don't remember if I used the stock coil mount and somehow "rolled" it forward or away from the Holley carb or not. This is what I have on my '69 440 GTX with a Holley 770 Street Avenger. No clearance problem with the coil and carb. (yes at the time a little backfire problem since fixed )
[Re: Kudakidd]
#3110810
01/11/23 12:16 PM
01/11/23 12:16 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
A Holley carburetor and the stock coil location on a 440. Any ideas? 6pack style coil bracket mounted forward ? What's the issue , the fuel line ?
[Re: topside]
#3110811
01/11/23 12:18 PM
01/11/23 12:18 PM
JohnRR
U.S.S.A.
A piece of flat stock under the coil bracket to move it forward works. That's what I think is shown in the photos. I have done that in the past with a small piece of alum flat stock .
[Re: topside]
#3110980
01/11/23 09:29 PM
01/11/23 09:29 PM
Posts: 7,861 Witness Protection Program
Kudakidd
JohnRR, the issue is the Holley front bowl on the center-hung float style; much longer carb than the Carters or the side-hung float Holleys. EXACTLY! Working on using a different coil bracket. The E-Booger relocation bracket didn't quite cut it.
[Re: topside]
#3111119
01/12/23 10:28 AM
01/12/23 10:28 AM
JohnRR
U.S.S.A.
JohnRR, the issue is the Holley front bowl on the center-hung float style; much longer carb than the Carters or the side-hung float Holleys. Yes that I know , Thinking about it more ... and looking at an online picture ... the plate I made was to get the coil closer to where it needed to be ... I was using a DP4B which moved the coil to the opposite side of the manifold.
[Re: Kudakidd]
#3111120
01/12/23 10:30 AM
01/12/23 10:30 AM
JohnRR
U.S.S.A.
JohnRR, the issue is the Holley front bowl on the center-hung float style; much longer carb than the Carters or the side-hung float Holleys. EXACTLY! Working on using a different coil bracket. The E-Booger relocation bracket didn't quite cut it. What didn't work with that bracket , it would be similar to using the 6pk coil bracket ???
[Re: Ronnman]
#3111518
01/13/23 11:38 AM
01/13/23 11:38 AM
Posts: 3,384 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Nice fabrication job--I'm going to need to make something like that as well.
Previous owner of my car installed a center-hung holley and I have the oval air cleaner for the fresh air hood on my 69 383 to contend with as well. The fuel line for the front bowl is causing me headaches especially.
Lot of stuff crammed into one small location.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
