Can't occupy the same space #3110678
01/10/23 08:50 PM
01/10/23 08:50 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
A Holley carburetor and the stock coil location on a 440. Any ideas?
Re: Can't occupy the same space [Re: Kudakidd] #3110691
01/10/23 09:30 PM
01/10/23 09:30 PM
All the lo po C body 440 from 1966 or maybe 1967 to 1971 had Holley 4 barrels with coils shruggy scope
Re: Can't occupy the same space [Re: Kudakidd] #3110693
01/10/23 09:53 PM
01/10/23 09:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
CH4B will fix it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Can't occupy the same space [Re: 3hundred] #3110696
01/10/23 10:00 PM
01/10/23 10:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the factory holleys used side pivot bowls not center pivot.
Re: Can't occupy the same space [Re: lewtot184] #3110726
01/11/23 12:41 AM
01/11/23 12:41 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Also there is a motorhome coil bracket that move the coil forward.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Can't occupy the same space [Re: Kudakidd] #3110736
01/11/23 02:33 AM
01/11/23 02:33 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I don't remember if I used the stock coil mount and somehow "rolled" it forward or away from the Holley carb or not. This is what I have on my '69 440 GTX with a Holley 770 Street Avenger. No clearance problem with the coil and carb. (yes at the time a little backfire problem blush since fixed smile )
Re: Can't occupy the same space [Re: A12] #3110801
01/11/23 11:53 AM
01/11/23 11:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A piece of flat stock under the coil bracket to move it forward works.
That's what I think is shown in the photos.
Re: Can't occupy the same space [Re: Kudakidd] #3110810
01/11/23 12:16 PM
01/11/23 12:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
6pack style coil bracket mounted forward ? What's the issue , the fuel line ?
Re: Can't occupy the same space [Re: topside] #3110811
01/11/23 12:18 PM
01/11/23 12:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have done that in the past with a small piece of alum flat stock .
Re: Can't occupy the same space [Re: JohnRR] #3110836
01/11/23 01:22 PM
01/11/23 01:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
JohnRR, the issue is the Holley front bowl on the center-hung float style; much longer carb than the Carters or the side-hung float Holleys.
Re: Can't occupy the same space [Re: topside] #3110980
01/11/23 09:29 PM
01/11/23 09:29 PM
Kudakidd Offline OP
Kudakidd  Offline OP
EXACTLY! Working on using a different coil bracket. The E-Booger relocation bracket didn't quite cut it.
Re: Can't occupy the same space [Re: Kudakidd] #3110999
01/11/23 10:39 PM
01/11/23 10:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Is the one Ebooger sells the same one as The AR Engineering bracket?
https://arengineering.com/products/horizontal-mount-big-blocks/
Gus beer
64 Plymouth Savoy
Dana 60
Re: Can't occupy the same space [Re: lewtot184] #3111026
01/11/23 11:25 PM
01/11/23 11:25 PM
iagree up
Re: Can't occupy the same space [Re: fourgearsavoy] #3111028
01/11/23 11:31 PM
01/11/23 11:31 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Gus beer
Yup. And about $2 more!
Re: Can't occupy the same space [Re: topside] #3111119
01/12/23 10:28 AM
01/12/23 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that I know ,
Thinking about it more ... and looking at an online picture ... the plate I made was to get the coil closer to where it needed to be ... I was using a DP4B which moved the coil to the opposite side of the manifold.
Re: Can't occupy the same space [Re: Kudakidd] #3111120
01/12/23 10:30 AM
01/12/23 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What didn't work with that bracket , it would be similar to using the 6pk coil bracket ???
Re: Can't occupy the same space [Re: JohnRR] #3111373
01/12/23 09:20 PM
01/12/23 09:20 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Damn Shaker base plate and cables. John you still attending the Big Daddy Show?
Re: Can't occupy the same space [Re: Kudakidd] #3111509
01/13/23 11:21 AM
01/13/23 11:21 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I just fabricated a 1/16” aluminum extension plate to move the coil forward. My pics are on a 383 with a Demon carb, but I have done it on a 440 as well.
Ron
DD3C6445-4AB3-44A9-BF46-F9199E50C22C.jpeg36F8D4CC-3229-4AF6-BB06-E88325E61454.jpegCFB36B7B-234B-4BB3-9869-F1F48F8A78BE.jpeg
Re: Can't occupy the same space [Re: Ronnman] #3111518
01/13/23 11:38 AM
01/13/23 11:38 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Nice fabrication job--I'm going to need to make something like that as well.
Previous owner of my car installed a center-hung holley and I have the oval air cleaner for the fresh air hood on my 69 383 to contend with as well. The fuel line for the front bowl is causing me headaches especially.
Lot of stuff crammed into one small location.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Can't occupy the same space [Re: wingman] #3111533
01/13/23 12:01 PM
01/13/23 12:01 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
The six-pack coil bracket is perfect for this kind of thing. Factory engineered and readily available.
