SRT seats in a Road runner #3105761
12/26/22 06:07 PM
12/26/22 06:07 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Looking for a little wiring help. Pulled the seats out of an 05 SRT 300. I can move the motors by hot wiring them directly but would like to be able to wire up the plug and have full functionality.
Anyone done this before ?
Re: SRT seats in a Road runner [Re: FastmOp] #3105804
12/26/22 09:58 PM
12/26/22 09:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Don't suppose you have the seat switch available?
Probably wouldn't matter anyway, the seat control probably runs through an onboard computer.
Back in the old days, the power came in central, then the switch position determine the power and the ground for each movement. The direction the power and ground traveled determined which way the seat moved. Power the seats in one direction the seats moved in one direction, reverse the wires, the seat moved in the other direction. Seat movement was: seat front up or down, rear seat movement up or down, and seat track movement, forward and reverse.
Then they added Lombard movement, in or out.
Then heated seats, backrest heat on or off and seat heat on or off.
When they added the computer, everything ran off one or two switches based on a resistance factor for each operation. For the most part, there are no off or no on positions anymore. Good luck!
Re: SRT seats in a Road runner [Re: poorboy] #3105845
12/27/22 06:30 AM
12/27/22 06:30 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The control switches for the seats are on the lower part of the seat on the side that faces the door.
The only switch that's anywhere else is the heated seat switch which is on the dash in the center below the radio.
Re: SRT seats in a Road runner [Re: SNK-EYZ] #3105864
12/27/22 10:19 AM
12/27/22 10:19 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Thanks gents.
I figured it was going to suck. I still have the SRT 300 here if I need to get parts. The switchs have 4 green wires going to them. The motors have 4 each. 2 green and 2 purple wires at each motor. I'll get some pics in a few and post them to see if that helps.
Not worried about the bun warmers, this is a drag and drive type car in fair weather.
Combo is a built 6.1 with a Procharger. 727 with a break, Dana 60
Re: SRT seats in a Road runner [Re: FastmOp] #3105868
12/27/22 10:22 AM
12/27/22 10:22 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My buddy tried to put a pair of newer Challenger buckets in his Chevelle. They were just too big and bulky. He didn't like them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: SRT seats in a Road runner [Re: 6PKRTSE] #3105870
12/27/22 10:32 AM
12/27/22 10:32 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Those seats look good in there, hope you figure it out. up
Re: SRT seats in a Road runner [Re: bobby66] #3105885
12/27/22 11:33 AM
12/27/22 11:33 AM
wheeling, west virginia
W
wvjohn Offline
wvjohn  Offline
W
put a set of 2014 challenger seats in my daughters 1992 cummins d 350 2 wheel drive extended cap pickup. wiring on those were simple, just finding what wire did what.then just had to make mounts.
Re: SRT seats in a Road runner [Re: wvjohn] #3105891
12/27/22 11:59 AM
12/27/22 11:59 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Anyone know this stuff, that black box looks like it has voodoo smoke in it smoke
Re: SRT seats in a Road runner [Re: FastmOp] #3105893
12/27/22 12:01 PM
12/27/22 12:01 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Switch wires
Re: SRT seats in a Road runner [Re: FastmOp] #3105898
12/27/22 12:14 PM
12/27/22 12:14 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I need the seats to function because I'm going to let some friends drive it and one guy is tall and one gal is short lmao.
It's going to be most, 1st trans break launch lmfao.
Re: SRT seats in a Road runner [Re: FastmOp] #3105899
12/27/22 12:20 PM
12/27/22 12:20 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I think the easy route is to get a FSM for the '05 SRT 300, or at least the page(s) that cover the seat wiring.
Re: SRT seats in a Road runner [Re: Fat_Mike] #3105902
12/27/22 12:27 PM
12/27/22 12:27 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Oops lol
Re: SRT seats in a Road runner [Re: FastmOp] #3105912
12/27/22 01:50 PM
12/27/22 01:50 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
https://www.lxforums.com/threads/new-service-manual-download-link.24486/page-23
Links for FSM’s are on the last page of this post. You may have to try a couple to find one that works. I had a couple of them but deleted them when I sold my Magnum.
Dennis
Re: SRT seats in a Road runner [Re: cudaboy] #3105915
12/27/22 01:58 PM
12/27/22 01:58 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Thanks neighbor.
Just poking around with the ohm meter I get signal in 6 spots with 5 wires lmao. That's coming through the black box.
The numbers wrote on the box are for the white plug. Figure there either ground or power lol.
Re: SRT seats in a Road runner [Re: FastmOp] #3105951
12/27/22 03:58 PM
12/27/22 03:58 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
you have heat and memory in those seats as well. separate the harness and follow the wires back to their motors, after that it should be not bad
Re: SRT seats in a Road runner [Re: chrisf] #3105984
12/27/22 08:10 PM
12/27/22 08:10 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
The black box in your pic should be the memory seat module. I sent you a PM for your email. I can send you wiring diagrams for the seat switches and motor. For some reason I can't copy them and paste them hear.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: SRT seats in a Road runner [Re: Dartsport540] #3105988
12/27/22 08:18 PM
12/27/22 08:18 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
This is why Moparts is what it is. I help and I get help . Thanks gents
Re: SRT seats in a Road runner [Re: FastmOp] #3106071
12/28/22 07:58 AM
12/28/22 07:58 AM
Ringtown, Pa.
Ringtown, Pa.
Wiring diagrams sent
Attached PDF document
Re: SRT seats in a Road runner [Re: Dartsport540] #3106072
12/28/22 07:59 AM
12/28/22 07:59 AM
Ringtown, Pa.
Ringtown, Pa.
It worked. I attached wiring diagrams here also, for others to see, if needed.
Re: SRT seats in a Road runner [Re: Dartsport540] #3106142
12/28/22 03:55 PM
12/28/22 03:55 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
So does the 1st pdf show power coming into one place ?
And not using the black box.
