Re: SRT seats in a Road runner
[Re: FastmOp]
#3105804
12/26/22 09:58 PM
12/26/22 09:58 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
Don't suppose you have the seat switch available? Probably wouldn't matter anyway, the seat control probably runs through an onboard computer.
Back in the old days, the power came in central, then the switch position determine the power and the ground for each movement. The direction the power and ground traveled determined which way the seat moved. Power the seats in one direction the seats moved in one direction, reverse the wires, the seat moved in the other direction. Seat movement was: seat front up or down, rear seat movement up or down, and seat track movement, forward and reverse.
Then they added Lombard movement, in or out.
Then heated seats, backrest heat on or off and seat heat on or off.
When they added the computer, everything ran off one or two switches based on a resistance factor for each operation. For the most part, there are no off or no on positions anymore. Good luck!
[Re: poorboy]
#3105845
12/27/22 06:30 AM
12/27/22 06:30 AM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
Don't suppose you have the seat switch available? The control switches for the seats are on the lower part of the seat on the side that faces the door. The only switch that's anywhere else is the heated seat switch which is on the dash in the center below the radio.
[Re: FastmOp]
#3105868
12/27/22 10:22 AM
12/27/22 10:22 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
My buddy tried to put a pair of newer Challenger buckets in his Chevelle. They were just too big and bulky. He didn't like them.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: cudaboy]
#3105915
12/27/22 01:58 PM
12/27/22 01:58 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Thanks neighbor.
Just poking around with the ohm meter I get signal in 6 spots with 5 wires lmao. That's coming through the black box. The numbers wrote on the box are for the white plug. Figure there either ground or power lol.
[Re: chrisf]
#3105984
12/27/22 08:10 PM
12/27/22 08:10 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
The black box in your pic should be the memory seat module. I sent you a PM for your email. I can send you wiring diagrams for the seat switches and motor. For some reason I can't copy them and paste them hear.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: FastmOp]
#3106071
12/28/22 07:58 AM
12/28/22 07:58 AM
Dartsport540
Ringtown, Pa.
Wiring diagrams sent
[Re: Dartsport540]
#3106072
12/28/22 07:59 AM
12/28/22 07:59 AM
Dartsport540
Ringtown, Pa.
It worked. I attached wiring diagrams here also, for others to see, if needed.
