Re: IS THERE A TORQUE ON HURST MOUNTING PLATE
[Re: superbird]
#3101328
12/11/22 03:02 PM
12/11/22 03:02 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Does anyone know if there is a torque on the Allen head screws the hold the mounting plate to the tail shaft on a 833. I have spent 20 minutes looking in the service manual and can't find anything Hurst specs are 10 lbs... Just my $0.02...
[Re: Cab_Burge]
#3101466
12/11/22 10:55 PM
12/11/22 10:55 PM
Posts: 15,338 Omaha Ne
TJP
Omaha Ne
I've never heard any mention of a torque number to use on them, measure the thread diameter, I'm thinking it is 3/8 course thread grade five fasteners, but make sure and look up the torque for that size. I wouldn't hesitate to use between 25 and 30 Ft. lbs. with red Loctite I would also Loctite (Red or Blue should be fine) the shifter mounting bolts. Do remember to heat the fasteners on the mounting plate if you need to remove it later. I have had the allens round out if one tries to remove them without a little heat. it doesn't take a lot but really helps in removal without destroying the fastener
[Re: 71GTX471]
#3101993
12/13/22 04:28 PM
12/13/22 04:28 PM
Posts: 43,152 Bend,OR USA
Cab_Burge
A true machinic knows tight vs too tight. I remember hearing years ago an older mechanic say I have a calibrated elbow when ask why he wasn't using a torque wrench when working on his cars
[Re: 71GTX471]
#3102058
12/13/22 08:28 PM
12/13/22 08:28 PM
Posts: 6,237 nowhere
Sniper
nowhere
A true machinic knows tight vs too tight. Appropriate that you misspelled mechanic.
[Re: Cab_Burge]
#3102837
12/16/22 12:55 PM
12/16/22 12:55 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
A true machinic knows tight vs too tight. I remember hearing years ago an older mechanic say I have a calibrated elbow when ask why he wasn't using a torque wrench when working on his cars It just comes naturally with many years of experience, but there are many cases a torque wrench is mandatory such as K frame to frame rail bolts.
