IS THERE A TORQUE ON HURST MOUNTING PLATE #3101298
12/11/22 01:34 PM
12/11/22 01:34 PM
milwaukee
superbird Offline OP
milwaukee
Does anyone know if there is a torque on the Allen head screws the hold
the mounting plate to the tail shaft on a 833.
I have spent 20 minutes looking in the service manual
and can't find anything
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: superbird] #3101303
12/11/22 01:52 PM
12/11/22 01:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've never heard any mention of a torque number to use on them, measure the thread diameter, I'm thinking it is 3/8 course thread grade five fasteners, but make sure scope and look up the torque for that size.
I wouldn't hesitate to use between 25 and 30 Ft. lbs. with red Loctite scope wrench luck grin up
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Cab_Burge] #3101310
12/11/22 02:06 PM
12/11/22 02:06 PM
moparx Offline
moparx  Offline
crank 'em up till they break or strip the threads, then back 'em off 1/2 a thread................... biggrin [i couldn't resist ! boogie]
beer
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: superbird] #3101328
12/11/22 03:02 PM
12/11/22 03:02 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Hurst specs are 10 lbs...
Just my $0.02... wink
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Sinitro] #3101334
12/11/22 03:16 PM
12/11/22 03:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are you screwing into aluminum? Then be very careful you select the right spec otherwise your next post will be "should I use a helicoil?"
https://www.engineersedge.com/torque_table_sae.htm
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Sniper] #3101363
12/11/22 05:08 PM
12/11/22 05:08 PM
The early NP833 main cases and tail shaft housing are cast steel, the adapter is cast aluminum with two mounting holes through them to hold the adapter onto the tail shaft housings wrench
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Cab_Burge] #3101428
12/11/22 08:50 PM
12/11/22 08:50 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Some Serviceable Loctite and that will be fine, with a good tightening by hand. No need to over-think such things.
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Cab_Burge] #3101466
12/11/22 10:55 PM
12/11/22 10:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
I would also Loctite (Red or Blue should be fine) the shifter mounting bolts. Do remember to heat the fasteners on the mounting plate if you need to remove it later. I have had the allens round out if one tries to remove them without a little heat. it doesn't take a lot but really helps in removal without destroying the fastener wink
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: TJP] #3101522
12/12/22 09:40 AM
12/12/22 09:40 AM
milwaukee
milwaukee
Thanks guys.
I wanted to ask cause i have a tendency to over tighten stuff
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: superbird] #3101704
12/12/22 08:27 PM
12/12/22 08:27 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
A true machinic knows tight vs too tight.
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: 71GTX471] #3101745
12/12/22 09:50 PM
12/12/22 09:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My elbow pops smile LOL beer
I was just thinking a Torx socket will take more torque but not sure how much shruggy beer
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Sniper] #3101810
12/13/22 01:27 AM
12/13/22 01:27 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
I'd recommend Time Sert. Hopefully it doesn't come to that.
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: 71GTX471] #3101993
12/13/22 04:28 PM
12/13/22 04:28 PM
I remember hearing years ago an older mechanic say I have a calibrated elbow when ask why he wasn't using a torque wrench when working on his cars work shruggy
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: 71GTX471] #3102058
12/13/22 08:28 PM
12/13/22 08:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Appropriate that you misspelled mechanic.
Re: IS THERE A TORQUE ON HURST MOUNTING PLATE [Re: Cab_Burge] #3102837
12/16/22 12:55 PM
12/16/22 12:55 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
It just comes naturally with many years of experience, but there are many cases a torque wrench is mandatory such as K frame to frame rail bolts.
