Page 2 of 3 1 2 3
Re: Block sleeves [Re: madscientist] #3100072
12/06/22 11:38 AM
12/06/22 11:38 AM
New York
polyspheric Offline
polyspheric  Offline
New York
W/r/t "Get the thickest sleeve you can"
Because you know exactly how thick the walls are in each direction of all 8 cylinders.
Where can I look this up?
Boffin Emeritus
Re: Block sleeves [Re: polyspheric] #3100077
12/06/22 12:05 PM
12/06/22 12:05 PM
Washington
madscientist Offline
Washington
I guess I need to type out WITHIN REASON. It’s called using your head.
Every sleeve EVER is under nominal by at least .030 so IF you chose a nominally sized sleeve that is thin and you bore most of it out to get to size what did you gain?
Have you ever set a sleeve? Just one? If so, you’d understand this.
Re: Block sleeves [Re: madscientist] #3100263
12/06/22 10:53 PM
12/06/22 10:53 PM
NY
B1duster Offline
B1duster  Offline
NY
Is it possible to sleeve back to 4.310 from 4.53 ?
From the list above, could csl2259 work ? OD 4.5655 1/8. 6 3/4
What if you bored block to 4.564 and left a half inch
at the bottom 4.53. Then machine the outside half inch bottom of sleeve
to 4.531 You’d have a .017 step, 1/2 inch from the bottom of the cylinder on the back side of sleeve.
Install and Finish bore to 4.31
Is the tiny step enough ?
Re: Block sleeves [Re: B1duster] #3100288
12/07/22 12:28 AM
12/07/22 12:28 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Could use these. Turn them to 4.528 drive them in
Re: Block sleeves [Re: cudaman1969] #3100308
12/07/22 02:07 AM
12/07/22 02:07 AM
NY
B1duster Offline
B1duster  Offline
NY
Think you mean 4.532. What bore are they ?
Re: Block sleeves [Re: B1duster] #3100311
12/07/22 04:15 AM
12/07/22 04:15 AM
fredericksburg,va
fredericksburg,va
Not sure what you mean by ‘they’ but those sleeves are out a older fuel block are 4.70 top and 4.63 at bottom, 4.31 inside. My block bore is 4.530 so if turn them to 4.529, heat the block, chill the sleeve they should drop in. I’ll cut the lip down then make a cutter to cut top of block to accept that lip so it will not move (which I doubt). I think those sleeves are some good material to support a fuel engine. KB sleeves if I remember right. I had vagly thought of using them but after reading the posts they might be the best option plus they where free.
Re: Block sleeves [Re: cudaman1969] #3100327
12/07/22 09:22 AM
12/07/22 09:22 AM
an8sec70cuda Offline
The sleeve's OD needs to be larger than the bore diameter so there's a press fit. I'd still bore the block out slightly to get the step at the bottom for the sleeve to sit on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Block sleeves [Re: cudaman1969] #3100399
12/07/22 01:12 PM
12/07/22 01:12 PM
NY
B1duster Offline
B1duster  Offline
NY
Not sure what you mean by ‘they’ but those sleeves are out an older fuel block are 4.70 top and 4.63 at bottom, 4.31 inside. My block bore is 4.530 so if turn them to 4.529, heat the block, chill the sleeve they should drop in. I’ll cut the lip down then make a cutter to cut top of block to accept that lip so it will not move (which I doubt). I think those sleeves are some good material to support a fuel engine. KB sleeves if I remember right. I had vagly thought of using them but after reading the posts they might be the best option plus they where free.
Lol
They, those, them
Kinda like the 3 who’s
Who knows, who cares and who gives a [censored]
I’m sure you know you really should start with a fresh bore but
If you turn them to fit the 4.53 “they” will still be .110 wall
Re: Block sleeves [Re: B1duster] #3100402
12/07/22 01:19 PM
12/07/22 01:19 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
You need a step or a flange in my opinion, and you need to be .001 to .0015 over the bore dia. You maynot need a step or flange at .003 or better.
Re: Block sleeves [Re: B1MAXX] #3100407
12/07/22 01:26 PM
12/07/22 01:26 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What kind of block are we talking here?
Re: Block sleeves [Re: B1MAXX] #3100418
12/07/22 02:13 PM
12/07/22 02:13 PM
NY
B1duster Offline
B1duster  Offline
NY
Probably an old mega block,
at 4.53 I’d be looking for the cheapest way out also
instead of spending $1900 on pistons
Re: Block sleeves [Re: B1duster] #3100454
12/07/22 03:51 PM
12/07/22 03:51 PM
fredericksburg,va
fredericksburg,va
Ditto
Re: Block sleeves [Re: cudaman1969] #3100572
12/08/22 08:37 AM
12/08/22 08:37 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Ok, those sleeves pictured look like they are for an aluminum block. Those are usually made of different material than cast iron sleeves (much harder to machine) But if your going to just mic the bores and machine them, you need a flange left on the top of the bores, which means you need to machine the top of the bore to accept it.
Re: Block sleeves [Re: B1MAXX] #3100574
12/08/22 08:48 AM
12/08/22 08:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Also after getting more of the picture, With sound bores and flanged sleeves you could be at .0005 to .001 for this.
What is the condition of the bores? Finished honed and straight?
Re: Block sleeves [Re: B1MAXX] #3100599
12/08/22 11:17 AM
12/08/22 11:17 AM
fredericksburg,va
fredericksburg,va
Yes good finish and straight, my concern when looking for pistons from the big engine builders, they said they never go over standard (4.5) because when bored there’s not enough material left between the cylinders = blown head gasket. I guess they made throw away blocks. Then the other can of worms is if all 8 holes are sleeved how weak-thin will cylinders be then (Siamese block) I feel like I’m in no mans land. I have everything there for this engine waiting now in limbo. One other thought, can standard pistons be coated .030?
Re: Block sleeves [Re: cudaman1969] #3100642
12/08/22 01:20 PM
12/08/22 01:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
.003 would be pushing it for a coating let alone .030.
4.53 should not present a head gasket problem.
I would think one of the major piston companies could do a 4.53 for way less than 1900$
Re: Block sleeves [Re: B1MAXX] #3100643
12/08/22 01:26 PM
12/08/22 01:26 PM
Diamond made me a set of 4.510" hemi pistons and they were over $1700 two years ago.
CHIP
Re: Block sleeves [Re: an8sec70cuda] #3100644
12/08/22 01:31 PM
12/08/22 01:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
maybe try a different brand.
Re: Block sleeves [Re: B1MAXX] #3100645
12/08/22 01:37 PM
12/08/22 01:37 PM
I agree, I was just saying I don't think he's too far off w/ his $1900 estimate.
I'd still rather run the block at 4.530" bore than put 8 sleeves in it.
CHIP
Re: Block sleeves [Re: an8sec70cuda] #3100652
12/08/22 01:54 PM
12/08/22 01:54 PM
fredericksburg,va
fredericksburg,va
Just for kicks I went to JE site and looked BB Chevy pistons, !! 4.53 1.52 ch .990 pin $91.00 ?!! Now that flat top only give me 8-1 compression.. but.. I would do in a street engine on pump gas. $730 instead of the $1900 quoted. lol
Page 2 of 3 1 2 3
