Originally Posted by polyspheric
W/r/t "Get the thickest sleeve you can"
Because you know exactly how thick the walls are in each direction of all 8 cylinders.
Where can I look this up?
I guess I need to type out WITHIN REASON. It’s called using your head.
Every sleeve EVER is under nominal by at least .030 so IF you chose a nominally sized sleeve that is thin and you bore most of it out to get to size what did you gain?
Have you ever set a sleeve? Just one? If so, you’d understand this.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
