Page 1 of 3 1 2 3
Block sleeves #3099491
12/04/22 01:49 PM
12/04/22 01:49 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
What is the normal thickness of a sleeve? Let’s say for the 440 standard bore. Can one order any outside diameter?
Re: Block sleeves [Re: cudaman1969] #3099499
12/04/22 02:04 PM
12/04/22 02:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call Darton and see scope twocents
I like and try to make sure all the blocks I have sleeves install in are Darton brand Ductile Iron sleeves not your standard over the counter cheap rebuilder sleeves tsk
Make sure your machine shop knows how to properly install them also scope twocents
Re: Block sleeves [Re: cudaman1969] #3099513
12/04/22 02:39 PM
12/04/22 02:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
1/16" wall
Boffin Emeritus
Re: Block sleeves [Re: polyspheric] #3099558
12/04/22 05:04 PM
12/04/22 05:04 PM
fredericksburg,va
fredericksburg,va
Originally Posted by polyspheric
1/16" wall
Wow, that is thin
Re: Block sleeves [Re: polyspheric] #3099564
12/04/22 05:33 PM
12/04/22 05:33 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I thing you dropped a decimal number poly.
I don't believe i have ever checked a factory block that was only 0.0625 thick. 3/16 I would buy or even 1/8
Old Geezer Racing
Re: Block sleeves [Re: SCATPACK 1] #3099579
12/04/22 06:48 PM
12/04/22 06:48 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
3/32 is the most common size.
Re: Block sleeves [Re: SCATPACK 1] #3099610
12/04/22 08:24 PM
12/04/22 08:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Smaller than 1/16" invites distortion when installing.
Thicker than 1/16" invites transecting the water jacket. Only use a bigger size if you know it's been done before.
Boffin Emeritus
Re: Block sleeves [Re: polyspheric] #3099618
12/04/22 09:01 PM
12/04/22 09:01 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Look up the available sleeves 3/32 is the standard. they also come in 1/8 comonly.
1/16 is rare/special. Not many offer in that size.
Re: Block sleeves [Re: polyspheric] #3099619
12/04/22 09:02 PM
12/04/22 09:02 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Mike, on my 383, I had to have 2 sleeves installed. They were dartons and were spec'd for a chevy. .145" wall thickness, after boring/honing they were .095" wall.
Re: Block sleeves [Re: varunner] #3099620
12/04/22 09:07 PM
12/04/22 09:07 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
the melling sleeve for a 440 is p/n CSL121. it is 3/32 and an outside Dia. of 4.510
There is a 1/8 version but no 1/16.
Re: Block sleeves [Re: B1MAXX] #3099624
12/04/22 09:12 PM
12/04/22 09:12 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Also, melling makes thousands of standard sleeves, so yes you can pick a different one for a different application, if desired.
Re: Block sleeves [Re: B1MAXX] #3099799
12/05/22 01:12 PM
12/05/22 01:12 PM
Washington
madscientist Offline
Washington
This^^^^. Get the thickest sleeve you can with the closest nominal bore size you can find.
Re: Block sleeves [Re: madscientist] #3099802
12/05/22 01:20 PM
12/05/22 01:20 PM
an8sec70cuda Offline
On typical small and big block V8 engines, I never installed anything thinner than an 1/8" sleeve.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Block sleeves [Re: an8sec70cuda] #3099885
12/05/22 05:26 PM
12/05/22 05:26 PM
fredericksburg,va
fredericksburg,va
Well good answers but I didn’t want the cat out of the bag at first. My bore is 4.53, pistons are $1900 new, I have a set of 4.31 on shelf so I figured sleeve it down to that size, not even boring the block just get the nominal outside size, drive em in with green loctite then bore-hone to fit pistons.
Re: Block sleeves [Re: cudaman1969] #3099890
12/05/22 05:47 PM
12/05/22 05:47 PM
If you want to distort the bores drive them in, if not wanting to drive them in chill them in the freezer several days or pack them in dry ice and then drop them in.
Make sure the O.D. of the new sleeves is less than .0030 of the bore sizes, check all 8 bi=ores before ordering the sleeves. Most of the better auto machine shops I've used out here leave a small step at the bottom of the bores when prepping the blocks for sleeves scope up twocents
Re: Block sleeves [Re: cudaman1969] #3099899
12/05/22 06:06 PM
12/05/22 06:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I wouldn't rely on sleeves fitting an existing bore to many variances. They need to have a step to sit on also, unless you use a top flanged sleeve which still requires machining.
Re: Block sleeves [Re: B1MAXX] #3099906
12/05/22 06:16 PM
12/05/22 06:16 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Also on the freezing. I don't do it. I tried it once and with the frost that accumulates on the sleeve I didn't want water in there with the loctite. .001 to .0015 and send it home.
Re: Block sleeves [Re: cudaman1969] #3099974
12/05/22 10:47 PM
12/05/22 10:47 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Block sleeves [Re: an8sec70cuda] #3100005
12/06/22 12:41 AM
12/06/22 12:41 AM
PA
Scully Offline
Scully  Offline
PA
I've used the 3/32 sleeves many times and always chill them in the freezer, they're not always round so you have to take an average.
Re: Block sleeves [Re: Scully] #3100044
12/06/22 09:30 AM
12/06/22 09:30 AM
Yes to leaving a step at the bottom of the bore so the sleeve can't drop.
I'd throw the block in the hot tank for about 20 minutes and put the sleeve in the freezer for several hours. Take the block out and as soon as it was dry, drive the sleeve in w/ green loctite/sleevetite. I was concerned about the moisture from it being cold w/ the loctite, but never had an issue. Repaired one really bad 454 chevy block out of a tow truck once that had a huge piece of cylinder wall missing. Concerned enough that I told the owner I'd try it, but if it failed it was his, lol. It ran for several years that I know of after I fixed it. up
CHIP
Page 1 of 3 1 2 3
