Driveshafts #3099412
12/04/22 10:12 AM
12/04/22 10:12 AM
CA.
RAY1969CARS Offline OP
CA.
Hi guys, I have a 69 Dart 727 with 83/4 I wanted to upgrade to a better yolk heavier duty and was wondering what is the best donor car /truck I could take a driveshaft out and have it cut down??? Junkyard build
Thank you, Mopar or no car
The car just got a narrowed rear end moved the leaf springs in moved back the leaf springs a half inch
Re: Driveshafts [Re: RAY1969CARS] #3099419
12/04/22 10:25 AM
12/04/22 10:25 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Look at used Nascar drive shafts on ebay.
Re: Driveshafts [Re: RAY1969CARS] #3099422
12/04/22 10:39 AM
12/04/22 10:39 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Seeing that you may live in Cali there are probably tons of rust free shafts available to you. You should be able to find a clean B-body shaft to work with shruggy
DoctorDiff can hook you up with a nice CM shaft for less than you would think twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Driveshafts [Re: fourgearsavoy] #3099431
12/04/22 11:05 AM
12/04/22 11:05 AM
CA.
CA.
I saw the doctor diff deal I just think shipping would kill it
Re: Driveshafts [Re: RAY1969CARS] #3099489
12/04/22 01:43 PM
12/04/22 01:43 PM
Locomotion Offline
Locomotion  Offline
Aftermarket driveshaft with solid Spicer u-joints and billet steel yoke are good insurance, even if just footbraking. Used driveshafts are still old, "used" and will probably need shortening so you'll be spending some time and money at a driveshaft shop already. Might as well try to upgrade.
Re: Driveshafts [Re: Locomotion] #3099498
12/04/22 02:00 PM
12/04/22 02:00 PM
Call Mark Williams and Strange Engr. and compare them to each other and go from there scope twocents
Re: Driveshafts [Re: Cab_Burge] #3099560
12/04/22 05:14 PM
12/04/22 05:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Mark Williams ONLY, I will never use another Strange one again
Re: Driveshafts [Re: RAY1969CARS] #3099685
12/05/22 01:54 AM
12/05/22 01:54 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints.
America First!
Re: Driveshafts [Re: carnut68] #3099687
12/05/22 02:11 AM
12/05/22 02:11 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Not sure how much room you have but many trucks have large diameter 1 piece driveshafts (aluminum) you could cut down.
Re: Driveshafts [Re: carnut68] #3099726
12/05/22 09:59 AM
12/05/22 09:59 AM
an8sec70cuda Offline
[s][/s]
iagree Local truck shop makes shafts for me also. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Driveshafts [Re: an8sec70cuda] #3099778
12/05/22 12:15 PM
12/05/22 12:15 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Originally Posted by an8sec70cuda
[s][/s]
Yep, had a couple built at Inland Truck Parts locally.
I did the Strange deal through Dr. Diff once and it was fine, but Summit does the same deal cheaper.
'63 Dodge 330
11.19 @ 121 mph
Re: Driveshafts [Re: an8sec70cuda] #3099825
12/05/22 02:33 PM
12/05/22 02:33 PM
moparx Offline
moparx  Offline
[s][/s]
the only thing that makes me apprehensive about using a place that does truck shafts, even if their work is flawless, is the speed at which the shaft is balanced at.
most [?] truck places only balance at the slow[er] shaft speed[s] a truck sees, and not the high rpm needed for a car, especially if an overdrive transmission or gearvendors unit is being used.
beer
Re: Driveshafts [Re: moparx] #3099845
12/05/22 03:33 PM
12/05/22 03:33 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
[s][/s]
beer
And the ONLY people I found that can spin a drive shaft at used rpm is Mark Williams, I threw away a brand new Strange shaft, it had a high speed vibration, called Strange & they FINALLY admitted they can only spin them 500rpm ,so did the alum shaft I had before, did all the pinion angle adjustments ECT.ECT.ECT, got a Mark Williams one built & the car is SMOOTH as glass at 130 mph smile
