Re: Driveshafts
[Re: RAY1969CARS]
#3099419
12/04/22 10:25 AM
12/04/22 10:25 AM
moparpollack
Lil Herman
Lil Herman
85086
Look at used Nascar drive shafts on ebay.
Re: Driveshafts
[Re: RAY1969CARS]
#3099422
12/04/22 10:39 AM
12/04/22 10:39 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Seeing that you may live in Cali there are probably tons of rust free shafts available to you. You should be able to find a clean B-body shaft to work with DoctorDiff can hook you up with a nice CM shaft for less than you would think Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Driveshafts
[Re: RAY1969CARS]
#3099489
12/04/22 01:43 PM
12/04/22 01:43 PM
Posts: 5,894 Florida
Locomotion
Aftermarket driveshaft with solid Spicer u-joints and billet steel yoke are good insurance, even if just footbraking. Used driveshafts are still old, "used" and will probably need shortening so you'll be spending some time and money at a driveshaft shop already. Might as well try to upgrade.
Re: Driveshafts
[Re: Cab_Burge]
#3099560
12/04/22 05:14 PM
12/04/22 05:14 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
Mark Williams ONLY, I will never use another Strange one again
Re: Driveshafts
[Re: RAY1969CARS]
#3099685
12/05/22 01:54 AM
12/05/22 01:54 AM
Posts: 3,208 Md.
carnut68
Md.
Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints.
America First!
Re: Driveshafts
[Re: carnut68]
#3099687
12/05/22 02:11 AM
12/05/22 02:11 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Not sure how much room you have but many trucks have large diameter 1 piece driveshafts (aluminum) you could cut down.
Re: Driveshafts
[Re: carnut68]
#3099726
12/05/22 09:59 AM
12/05/22 09:59 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[s][/s] Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints. Local truck shop makes shafts for me also.
Re: Driveshafts
[Re: an8sec70cuda]
#3099778
12/05/22 12:15 PM
12/05/22 12:15 PM
Posts: 4,689 Wichita
GY3
Wichita
[s][/s] Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints. Local truck shop makes shafts for me also. Yep, had a couple built at Inland Truck Parts locally. I did the Strange deal through Dr. Diff once and it was fine, but Summit does the same deal cheaper.
Re: Driveshafts
[Re: an8sec70cuda]
#3099825
12/05/22 02:33 PM
12/05/22 02:33 PM
Posts: 19,488 north of coder
moparx
[s][/s] Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints. Local truck shop makes shafts for me also. the only thing that makes me apprehensive about using a place that does truck shafts, even if their work is flawless, is the speed at which the shaft is balanced at. most [?] truck places only balance at the slow[er] shaft speed[s] a truck sees, and not the high rpm needed for a car, especially if an overdrive transmission or gearvendors unit is being used.
Re: Driveshafts
[Re: moparx]
#3099845
12/05/22 03:33 PM
12/05/22 03:33 PM
CSK
Pattison Texas
[s][/s] Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints. Local truck shop makes shafts for me also. the only thing that makes me apprehensive about using a place that does truck shafts, even if their work is flawless, is the speed at which the shaft is balanced at. most [?] truck places only balance at the slow[er] shaft speed[s] a truck sees, and not the high rpm needed for a car, especially if an overdrive transmission or gearvendors unit is being used. And the ONLY people I found that can spin a drive shaft at used rpm is Mark Williams, I threw away a brand new Strange shaft, it had a high speed vibration, called Strange & they FINALLY admitted they can only spin them 500rpm ,so did the alum shaft I had before, did all the pinion angle adjustments ECT.ECT.ECT, got a Mark Williams one built & the car is SMOOTH as glass at 130 mph
