Re: Block sleeves
[Re: cudaman1969]
#3099499
12/04/22 02:04 PM
12/04/22 02:04 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
Re: Block sleeves
[Re: polyspheric]
#3099564
12/04/22 05:33 PM
12/04/22 05:33 PM
Posts: 1,505 TN
SCATPACK 1
TN
I thing you dropped a decimal number poly. I don't believe i have ever checked a factory block that was only 0.0625 thick. 3/16 I would buy or even 1/8
Old Geezer Racing
Re: Block sleeves
[Re: SCATPACK 1]
#3099610
12/04/22 08:24 PM
12/04/22 08:24 PM
Posts: 4,210 New York
polyspheric
New York
Smaller than 1/16" invites distortion when installing. Thicker than 1/16" invites transecting the water jacket. Only use a bigger size if you know it's been done before.
Boffin Emeritus
Re: Block sleeves
[Re: varunner]
#3099620
12/04/22 09:07 PM
12/04/22 09:07 PM
Posts: 2,006 Apollo, PA.
B1MAXX
Apollo, PA.
the melling sleeve for a 440 is p/n CSL121. it is 3/32 and an outside Dia. of 4.510
There is a 1/8 version but no 1/16.
Re: Block sleeves
[Re: B1MAXX]
#3099799
12/05/22 01:12 PM
12/05/22 01:12 PM
Posts: 4,457 Washington
madscientist
Washington
Also, melling makes thousands of standard sleeves, so yes you can pick a different one for a different application, if desired. This^^^^. Get the thickest sleeve you can with the closest nominal bore size you can find.
Re: Block sleeves
[Re: madscientist]
#3099802
12/05/22 01:20 PM
12/05/22 01:20 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
On typical small and big block V8 engines, I never installed anything thinner than an 1/8" sleeve.
Re: Block sleeves
[Re: cudaman1969]
#3099890
12/05/22 05:47 PM
12/05/22 05:47 PM
Cab_Burge
Well good answers but I didn’t want the cat out of the bag at first. My bore is 4.53, pistons are $1900 new, I have a set of 4.31 on shelf so I figured sleeve it down to that size, not even boring the block just get the nominal outside size, drive em in with green loctite then bore-hone to fit pistons. If you want to distort the bores drive them in, if not wanting to drive them in chill them in the freezer several days or pack them in dry ice and then drop them in. Make sure the O.D. of the new sleeves is less than .0030 of the bore sizes, check all 8 bi=ores before ordering the sleeves. Most of the better auto machine shops I've used out here leave a small step at the bottom of the bores when prepping the blocks for sleeves
Re: Block sleeves
[Re: an8sec70cuda]
#3100005
12/06/22 12:41 AM
12/06/22 12:41 AM
Posts: 201 PA
Scully
PA
On typical small and big block V8 engines, I never installed anything thinner than an 1/8" sleeve. I've used the 3/32 sleeves many times and always chill them in the freezer, they're not always round so you have to take an average.
Re: Block sleeves
[Re: Scully]
#3100044
12/06/22 09:30 AM
12/06/22 09:30 AM
an8sec70cuda
Yes to leaving a step at the bottom of the bore so the sleeve can't drop. I'd throw the block in the hot tank for about 20 minutes and put the sleeve in the freezer for several hours. Take the block out and as soon as it was dry, drive the sleeve in w/ green loctite/sleevetite. I was concerned about the moisture from it being cold w/ the loctite, but never had an issue. Repaired one really bad 454 chevy block out of a tow truck once that had a huge piece of cylinder wall missing. Concerned enough that I told the owner I'd try it, but if it failed it was his, lol. It ran for several years that I know of after I fixed it.
