Re: Advice for 3.38 stroke 400 pump gas motor
[Re: hemienvy]
#3099599
12/04/22 07:43 PM
12/04/22 07:43 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Just as with any other combo, best to have the cam/intake/headers/desired peak rpm all on the same page.
[Re: hemienvy]
#3099602
12/04/22 07:59 PM
12/04/22 07:59 PM
Posts: 4,206 New York
polyspheric
New York
B engines have very tight piston-to-head distance near TDC and limits lift during overlap and static CR due to the large chamber area. A longer rod makes this somewhat worse.
Boffin Emeritus
[Re: hemienvy]
#3099632
12/04/22 09:30 PM
12/04/22 09:30 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What's the rest of the combination going to be? I have no feel for why a dual plane like a Performer RPM would be better or worse based on your description so far.
Yes, the Trick Flow RB intake is tall, 6+", plus it'll be raised even higher w/ the Stage VI heads. That's definitely a "top end" intake, especially for 400-ish cubes. I run one on my RB 452 which makes peak HP at 6800.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: hemienvy]
#3099647
12/04/22 10:07 PM
12/04/22 10:07 PM
Brad_Haak
Loudoun County, VA
Runner sizes are similar; Trick Flow is better out of the box, but Victor is comparable w/ more work (IMO). I've run both, FWIW.
[Re: hemienvy]
#3099658
12/04/22 10:41 PM
12/04/22 10:41 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Any reason why?
I can see it if you were building something for 8500+rpm?
