Advice for 3.38 stroke 400 pump gas motor #3099543
12/04/22 04:14 PM
12/04/22 04:14 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have some Stage VI high port heads that need a home. I thought about a 406 big block with these heads. It will need a 440 intake.
I'll use long rods and lightweight pistons.
With an 850 carb of some sort and 1 7/8 headers it should be good for 7000~~7200 RPM. Should be around 10.2 or so compression.
I know this is not a common combination to build. It's just a big small block.
So what intake would you think, a single plane for this or maybe a 440 Performer RPM ?
What is the tallest single plane with standard sized ports, the Trick Flow ?
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099599
12/04/22 07:43 PM
12/04/22 07:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just as with any other combo, best to have the cam/intake/headers/desired peak rpm all on the same page.
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099602
12/04/22 07:59 PM
12/04/22 07:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
B engines have very tight piston-to-head distance near TDC and limits lift during overlap and static CR due to the large chamber area. A longer rod makes this somewhat worse.
Boffin Emeritus
Re: Advice for 3.38 stroke 400 pump gas motor [Re: polyspheric] #3099622
12/04/22 09:10 PM
12/04/22 09:10 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Yes what you guys say is true, so I'm asking about the intake. I think the rest of the parameters
are somewhat aligned. I don't have a cam design picked out yet either, I know how important
and unique that will be too. I'm wondering about the intake at the moment.
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099632
12/04/22 09:30 PM
12/04/22 09:30 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
What's the rest of the combination going to be? I have no feel for why a dual plane like a Performer RPM would be better or worse based on your description so far.
Yes, the Trick Flow RB intake is tall, 6+", plus it'll be raised even higher w/ the Stage VI heads. That's definitely a "top end" intake, especially for 400-ish cubes. I run one on my RB 452 which makes peak HP at 6800.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Advice for 3.38 stroke 400 pump gas motor [Re: Brad_Haak] #3099640
12/04/22 09:42 PM
12/04/22 09:42 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Edelbrock says 6500 RPM on a 440 for the Performer RPM, so I figured 10% more RPM for a 10% smaller engine.
Any 440 intake would not sit any higher on a 400 block / Stage VI motor than it would on a standard port head / 440 block.
Does the Trick Flow single plane have bigger runners than the Edelbrock Victor ?
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099647
12/04/22 10:07 PM
12/04/22 10:07 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Runner sizes are similar; Trick Flow is better out of the box, but Victor is comparable w/ more work (IMO). I've run both, FWIW.
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099658
12/04/22 10:41 PM
12/04/22 10:41 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Any reason why?
I can see it if you were building something for 8500+rpm?
Re: Advice for 3.38 stroke 400 pump gas motor [Re: INTMD8] #3099680
12/05/22 12:35 AM
12/05/22 12:35 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I don't think the heads are big enough for 8500, even with the smaller cubic inches.
Now B1 heads on a 406..................
Re: Advice for 3.38 stroke 400 pump gas motor [Re: hemienvy] #3099834
12/05/22 02:56 PM
12/05/22 02:56 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
This will run good if the heads are right. Hutch had a similar combo. But as has been said it's all the parts pairing. Definitly a single plane intake. I have a good used set of pistons from AndyF I never used and think it was a 6.86 rod with the 3.38 crank in a 400 block if you're interested.
Re: Advice for 3.38 stroke 400 pump gas motor [Re: HardcoreB] #3100815
12/09/22 09:48 AM
12/09/22 09:48 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Sorry for the delay replying to your PM.
