I have some Stage VI high port heads that need a home. I thought about a 406 big block with these heads. It will need a 440 intake.
I'll use long rods and lightweight pistons.
With an 850 carb of some sort and 1 7/8 headers it should be good for 7000~~7200 RPM. Should be around 10.2 or so compression.
I know this is not a common combination to build. It's just a big small block.
So what intake would you think, a single plane for this or maybe a 440 Performer RPM ?
What is the tallest single plane with standard sized ports, the Trick Flow ?
