Page 4 of 4 1 2 3 4
Re: Windage Trays...for big blocks [Re: 340Cuda] #3099527
12/04/22 03:18 PM
12/04/22 03:18 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Interesting results on the link below, I'm guessing the losses will be more for an 8 cylinder / bigger stroke as well. But it doesn't take into consideration the effects of acceleration and deceleration on the oil in the pan.
https://core.ac.uk/download/pdf/4403473.pdf
Re: Windage Trays...for big blocks [Re: Tig] #3101663
12/12/22 05:55 PM
12/12/22 05:55 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Well i ordered a scraper last week. It came today. Even has the extra splash pan i ordered with it.
Re: Windage Trays...for big blocks [Re: 340Cuda] #3101679
12/12/22 06:58 PM
12/12/22 06:58 PM
I make my own crank scrapers and install them between the block and windage trays with .030 to .060 clearances on the passenger side of the blocks up, I have heard from a very good engine builder in SO CA that the crankshaft scrapers they used on BB Chevy were worth no HP or torque improvement below 6000 RPM at WOT dyno testing, they made 30 HP gain at 8600 RPM on the same motor with almost identical weather conditions the next day after installing it work up
Re: Windage Trays...for big blocks [Re: Cab_Burge] #3101694
12/12/22 07:32 PM
12/12/22 07:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Saw a bunch of pans with these trays at PRI.
Doug
Re: Windage Trays...for big blocks [Re: dvw] #3101740
12/12/22 09:42 PM
12/12/22 09:42 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
Yea, I seen several also.
When I asked about pans for a big block Mopar, all i get was a blank stare, and the old "no, we don't"
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Page 4 of 4 1 2 3 4
