Re: Windage Trays...for big blocks
[Re: Hot 340]
#3097484
11/27/22 10:51 AM
11/27/22 10:51 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I'm using a combination of windage tray + crank scraper now. One thing I believe is the common windage trays don't have adequate drainage to help get the oil back into the sump.
With a standard OEM / MP style "short" tray, I added some vents as seen below.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3097486
11/27/22 10:54 AM
11/27/22 10:54 AM
Brad_Haak
Loudoun County, VA
However, I switched to a full-length style and went much further in terms of additional drain-back holes.
[Re: Brad_Haak]
#3097487
11/27/22 10:57 AM
11/27/22 10:57 AM
Brad_Haak
Loudoun County, VA
Tray on pan, plus scraper on tray on pan
Oil pressure steady up to 7200 RPM on engine dyno
[Re: Brad_Haak]
#3097528
11/27/22 01:05 PM
11/27/22 01:05 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I just put a summit tray in my hemi. I also added drain backs cause I’m using a scraper as well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: Hot 340]
#3097554
11/27/22 02:11 PM
11/27/22 02:11 PM
Posts: 4,206 New York
polyspheric
New York
Louvers (like a small hood scoop, as shown above) are the preferred shape for drain-back, because they work strongly in one direction (down) and resist back-flow. Simple holes flow equally in both directions.
IDK how to determine the exact height (below the crank, above the oil level). Ideally,
Boffin Emeritus
[Re: moparx]
#3097637
11/27/22 08:54 PM
11/27/22 08:54 PM
polyspheric
New York
Definitely. Best done with a tool shaped as a radius, from above, the larger the better. Th edges should point down if possible.
Round holes' area doesn't control the flow rate, since the edges are always a restriction (perhaps .020"). Bigger holes flow more in proportion to their area.
Boffin Emeritus
[Re: mopar dave]
#3097663
11/27/22 11:16 PM
11/27/22 11:16 PM
Posts: 1,362 Out of the State of Confusion
blue_stocker
Then there's the built-in tray/baffle combo...
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: Cab_Burge]
#3097694
11/28/22 08:24 AM
11/28/22 08:24 AM
Posts: 10,209 Someplace you aren't
SomeCarGuy
I put a tray in a 79 360 truck during a rear main seal change and could feel the difference right away.
I want my fair share
[Re: dvw]
#3097739
11/28/22 11:34 AM
11/28/22 11:34 AM
Posts: 10,022 MN
JERICOGTX
MN
The scraper and a tray do basicly the same job. The scraper is better at removing the oil clinging to the crank. Your talking .060" clearance to rotating parts vs inches. The tray can't get close enough to do that. The tray does keep the rotating oil and crank action from upsetting the oil in the pan. Heck I use a hand fitted scraper, directional screen in the pan, multiple baffles, trap doors, and a swinging pick up. Doug Those scrapers are nice. To bad I never received the one I ordered a year ago.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3097760
11/28/22 12:40 PM
11/28/22 12:40 PM
Posts: 9,835 MI, usa
dvw
MI, usa
The scraper and a tray do basicly the same job. The scraper is better at removing the oil clinging to the crank. Your talking .060" clearance to rotating parts vs inches. The tray can't get close enough to do that. The tray does keep the rotating oil and crank action from upsetting the oil in the pan. Heck I use a hand fitted scraper, directional screen in the pan, multiple baffles, trap doors, and a swinging pick up. Doug Those scrapers are nice. To bad I never received the one I ordered a year ago. Call Kevin. I found him pretty easy to deal with. Doug
[Re: JERICOGTX]
#3097766
11/28/22 01:08 PM
11/28/22 01:08 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: dvw]
#3097791
11/28/22 02:12 PM
11/28/22 02:12 PM
Posts: 10,022 MN
JERICOGTX
MN
The scraper and a tray do basicly the same job. The scraper is better at removing the oil clinging to the crank. Your talking .060" clearance to rotating parts vs inches. The tray can't get close enough to do that. The tray does keep the rotating oil and crank action from upsetting the oil in the pan. Heck I use a hand fitted scraper, directional screen in the pan, multiple baffles, trap doors, and a swinging pick up. Doug Those scrapers are nice. To bad I never received the one I ordered a year ago. Call Kevin. I found him pretty easy to deal with. Doug That is who I talked with. Easy to talk with... Never received what I ordered...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3097810
11/28/22 03:09 PM
11/28/22 03:09 PM
Brad_Haak
Loudoun County, VA
That is who I talked with. Easy to talk with... Never received what I ordered... It took me a couple of "reminder" calls to get one of the two I have. Like the product, but time to deliver was... unpredictable.
