Page 1 of 4 1 2 3 4
Windage Trays...for big blocks #3097483
11/27/22 09:41 AM
11/27/22 09:41 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Lots of differing opinions in the past....What is the final verdict? Dyno guys? (not talking about crank scrapers here, I know they work). What have you guys seen and which types work best?
Re: Windage Trays...for big blocks [Re: Hot 340] #3097484
11/27/22 09:51 AM
11/27/22 09:51 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I'm using a combination of windage tray + crank scraper now. One thing I believe is the common windage trays don't have adequate drainage to help get the oil back into the sump.
With a standard OEM / MP style "short" tray, I added some vents as seen below.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Windage Trays...for big blocks [Re: Brad_Haak] #3097486
11/27/22 09:54 AM
11/27/22 09:54 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
However, I switched to a full-length style and went much further in terms of additional drain-back holes.
Re: Windage Trays...for big blocks [Re: Brad_Haak] #3097487
11/27/22 09:57 AM
11/27/22 09:57 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Tray on pan, plus scraper on tray on pan
Oil pressure steady up to 7200 RPM on engine dyno
Re: Windage Trays...for big blocks [Re: Brad_Haak] #3097528
11/27/22 12:05 PM
11/27/22 12:05 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I just put a summit tray in my hemi. I also added drain backs cause I’m using a scraper as well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Windage Trays...for big blocks [Re: Hot 340] #3097554
11/27/22 01:11 PM
11/27/22 01:11 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Louvers (like a small hood scoop, as shown above) are the preferred shape for drain-back, because they work strongly in one direction (down) and resist back-flow.
Simple holes flow equally in both directions.
IDK how to determine the exact height (below the crank, above the oil level). Ideally,
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: polyspheric] #3097569
11/27/22 02:13 PM
11/27/22 02:13 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
if one were to use a dimple die on the added round holes, would that resist back-flow some ?
beer
Re: Windage Trays...for big blocks [Re: moparx] #3097570
11/27/22 02:22 PM
11/27/22 02:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The rotational pull of the crank & rods is pretty strong, so I've always adhered to the directional louver deal, which I open up a bit.
Crank scraper helps with pretty much anything you do.
Dimple-die on the round holes should help them act one-way, but a bunch of small round holes doesn't seem as effective, though they will obviously drain.
Easy enough to visualize the pan environment by rapidly stirring soup, though there's a bit more going on (pistons pumping)...
Re: Windage Trays...for big blocks [Re: moparx] #3097637
11/27/22 07:54 PM
11/27/22 07:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Definitely.
Best done with a tool shaped as a radius, from above, the larger the better. Th edges should point down if possible.
Round holes' area doesn't control the flow rate, since the edges are always a restriction (perhaps .020"). Bigger holes flow more in proportion to their area.
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: polyspheric] #3097644
11/27/22 08:22 PM
11/27/22 08:22 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Do windage trays really work? How effective are they really? It just seems to me the tray would hold the oil right under the crank and cause more problems than they are worth. I never used one in my small blocks, but i do have one in my current 511 because i was told i needed it. I'm contemplating using one in the 572 Hemi.
Re: Windage Trays...for big blocks [Re: mopar dave] #3097663
11/27/22 10:16 PM
11/27/22 10:16 PM
Out of the State of Confusion
blue_stocker Offline
Then there's the built-in tray/baffle combo...
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Windage Trays...for big blocks [Re: mopar dave] #3097664
11/27/22 10:22 PM
11/27/22 10:22 PM
I was told by one of the Mopar drag seminar engineers that Mopar had found a 5 HP increase on the 1968 383 magnum and 8 HP increase on the street Hemi and 440 magnum 375 HP 1968 motors while developing them in 1967 for both NASCAR and drag racing shruggy
Re: Windage Trays...for big blocks [Re: Cab_Burge] #3097694
11/28/22 07:24 AM
11/28/22 07:24 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I put a tray in a 79 360 truck during a rear main seal change and could feel the difference right away.
I want my fair share
Re: Windage Trays...for big blocks [Re: SomeCarGuy] #3097727
11/28/22 10:04 AM
11/28/22 10:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The scraper and a tray do basicly the same job. The scraper is better at removing the oil clinging to the crank. Your talking .060" clearance to rotating parts vs inches. The tray can't get close enough to do that. The tray does keep the rotating oil and crank action from upsetting the oil in the pan. Heck I use a hand fitted scraper, directional screen in the pan, multiple baffles, trap doors, and a swinging pick up.
Doug
Re: Windage Trays...for big blocks [Re: dvw] #3097739
11/28/22 10:34 AM
11/28/22 10:34 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
Those scrapers are nice. To bad I never received the one I ordered a year ago.
69 GTX 68 Road Runner
Re: Windage Trays...for big blocks [Re: JERICOGTX] #3097760
11/28/22 11:40 AM
11/28/22 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Call Kevin. I found him pretty easy to deal with.
Doug
Re: Windage Trays...for big blocks [Re: JERICOGTX] #3097766
11/28/22 12:08 PM
11/28/22 12:08 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Windage Trays...for big blocks [Re: dvw] #3097791
11/28/22 01:12 PM
11/28/22 01:12 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
Doug
That is who I talked with. Easy to talk with... Never received what I ordered...
Re: Windage Trays...for big blocks [Re: blue_stocker] #3097806
11/28/22 01:53 PM
11/28/22 01:53 PM
moparx Offline
moparx  Offline
kind of what i had in mind with the dimple die used on the holes. up
how does that setup work for you ?
beer
Re: Windage Trays...for big blocks [Re: JERICOGTX] #3097810
11/28/22 02:09 PM
11/28/22 02:09 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Doug
It took me a couple of "reminder" calls to get one of the two I have. Like the product, but time to deliver was... unpredictable.
Page 1 of 4 1 2 3 4
