Re: Need to buy a good distributor
[Re: hudsonhornet7x]
#3095975
11/21/22 11:28 AM
11/21/22 11:28 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I like the MSD pro billet distributors.
[Re: Dabee]
#3096030
11/21/22 01:37 PM
11/21/22 01:37 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
I like the MSD pro billet distributors. Agree Double agree....My Firecore one exploded when somthing came lose in it. Never seen an MSD do that.
#3096040
11/21/22 02:01 PM
11/21/22 02:01 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I am having a 470 put together and need to get a good distributor. It has been many years since I purchased one and would like to ask what is out there now that is not junk? Thanks for your time! Which block, B or R/B? What application and ignition being used? I like to use a stock looking aluminum Mopar factory with vacuum advance recurved by me, especially on street and strip cars to make most folks looking think It be stock, honest
[Re: Cab_Burge]
#3096069
11/21/22 03:29 PM
11/21/22 03:29 PM
Posts: 1,541 USA
hudsonhornet7x
USA
I am having a 470 put together and need to get a good distributor. It has been many years since I purchased one and would like to ask what is out there now that is not junk? Thanks for your time! Which block, B or R/B? What application and ignition being used? I like to use a stock looking aluminum Mopar factory with vacuum advance recurved by me, especially on street and strip cars to make most folks looking think It be stock, honest B Block. Street/Strip, need to buy a whole ignition.
[Re: Cab_Burge]
#3096073
11/21/22 03:38 PM
11/21/22 03:38 PM
Posts: 4,669 Wichita
GY3
Wichita
I am having a 470 put together and need to get a good distributor. It has been many years since I purchased one and would like to ask what is out there now that is not junk? Thanks for your time! Which block, B or R/B? What application and ignition being used? I like to use a stock looking aluminum Mopar factory with vacuum advance recurved by me, especially on street and strip cars to make most folks looking think It be stock, honest Same! I pull apart originals, clean them up, lube the centrifugal weights, add Mr. Gasket #925-B lightweight springs, and add the Hillman nylon collar since I usually destroy the stock ones taking them apart. I use them with an analog MSD 6AL and add a dial rev limiter and timing controller and the system has been flawless.
[Re: GY3]
#3096102
11/21/22 05:11 PM
11/21/22 05:11 PM
Posts: 1,030 ohio
67mprfan
ohio
https://progressionignition.com/shop/ols/categories/chryslerHaven't used 1 but I been considering it. I'm also running a 470 street strip
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#3096116
11/21/22 06:01 PM
11/21/22 06:01 PM
Posts: 9,825 MI, usa
dvw
MI, usa
I've never had issues with the O.E. stuff. When I built the racecar it was getting a crank trigger. I was just looking foe something to spin the rotor to the cap. I bought a 440 source clearance part that had no electronics for $25. Billet aluminum, polished, ball bearing, brass cap terminals. Diameter isn't bad either. I did have to clearance the edge of the cap to fit against this intake. Been running it for 10 years with MSD 7AL2. Flawless. Doug
#3096128
11/21/22 06:59 PM
11/21/22 06:59 PM
Cab_Burge
I'm not sure which brand and model ECU to use, sorry I buy all the MSD older race boxes like the MSD404b,404C, MSD7, MSD7C and so on to use on my street and strip builds along with the proper Mallory or MSD race coils I've had one MSD7 die on me while racing years ago on my old pump gas Duster Only one
[Re: Cab_Burge]
#3096180
11/21/22 10:13 PM
11/21/22 10:13 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Thanks all for your experiences. It seems as though there are more options than I thought previously. Some of them are pretty trick! I wonder who makes the Summit brand? Also, does anyone here use Davis Unified Ignition (DUI)? The MSD unit is probably what I will buy, but I want to educate myself.
#3096259
11/22/22 10:32 AM
11/22/22 10:32 AM
an8sec70cuda
Pretty sure Summit distributors are Firecore. Haven't heard much good about those. I have a BB Chevy stroker that I built...the owner brought me a Summit distributor for it. It looks ok, but we'll see when I get it running. Good friend has a Summit distributor in his B1 motor, but it's just a gutted unit used w/ a crank trigger.
Those DUI distributors are ridiculously HUGE. I suggest looking into them closely before getting one. They may work ok, but holy crap are they huge and ugly. I'm surprised they fit under some hoods, lol.
Even w/ the rust "issues" people complain about w/ the MSD distributors, I've never had a problem from one of them.
[Re: an8sec70cuda]
#3096340
11/22/22 03:25 PM
11/22/22 03:25 PM
Posts: 10,201 Someplace you aren't
SomeCarGuy
Halifax Hops is on the mopar boards and he has a pile of cores. Can build one up with any curve you want and all fresh and tested. I needed one about a year ago and he set it up for me. Been perfect.
I want my fair share
[Re: GY3]
#3096341
11/22/22 03:28 PM
11/22/22 03:28 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Same! I pull apart originals, clean them up, lube the centrifugal weights, add Mr. Gasket #925-B lightweight springs, and add the Hillman nylon collar since I usually destroy the stock ones taking them apart. I use them with an analog MSD 6AL and add a dial rev limiter and timing controller and the system has been flawless. Same here. Mr. Gasket spring kit and use the mag pickup to trigger a 6AL, and I have a start/step retard for when the nitrous is activated. If I ever go non-sequential EFI I'll weld the advance weights and continue to use it.
[Re: moparx]
#3110700
01/10/23 10:11 PM
01/10/23 10:11 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
The Firecore distributors have evolved to be a very reliable and impressive distributor. There have been a lot of updates and upgrades.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: SomeCarGuy]
#3110705
01/10/23 10:55 PM
01/10/23 10:55 PM
Posts: 3,163 Md.
carnut68
Md.
Halifax Hops is on the mopar boards and he has a pile of cores. Can build one up with any curve you want and all fresh and tested. I needed one about a year ago and he set it up for me. Been perfect. He's on A bodys only quite a bit.
America First!
