Need to buy a good distributor #3095968
11/21/22 11:09 AM
11/21/22 11:09 AM
USA
hudsonhornet7x Offline OP
USA
I am having a 470 put together and need to get a good distributor. It has been many years since I purchased one and would like to ask what is out there now that is not junk? Thanks for your time!
Re: Need to buy a good distributor [Re: hudsonhornet7x] #3095975
11/21/22 11:28 AM
11/21/22 11:28 AM
an8sec70cuda Offline
I like the MSD pro billet distributors. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need to buy a good distributor [Re: an8sec70cuda] #3095997
11/21/22 12:07 PM
11/21/22 12:07 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Agree
Re: Need to buy a good distributor [Re: Dabee] #3096029
11/21/22 01:36 PM
11/21/22 01:36 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Same.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Need to buy a good distributor [Re: Dabee] #3096030
11/21/22 01:37 PM
11/21/22 01:37 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Agree
Double agree....My Firecore one exploded when somthing came lose in it. Never seen an MSD do that.
Re: Need to buy a good distributor [Re: hudsonhornet7x] #3096040
11/21/22 02:01 PM
11/21/22 02:01 PM
Which block, B or R/B?
What application and ignition being used?
I like to use a stock looking aluminum Mopar factory with vacuum advance recurved by me, especially on street and strip cars to make most folks looking think confused It be stock, honest whistling
Re: Need to buy a good distributor [Re: Dragula] #3096041
11/21/22 02:02 PM
11/21/22 02:02 PM
moparx Offline
moparx  Offline
do the msd's still have the "rusting" problem of a few years ago, where after a short time and the cap was pulled, there seemed to be a lot of rust build up on the internal parts ?
beer
Re: Need to buy a good distributor [Re: Cab_Burge] #3096069
11/21/22 03:29 PM
11/21/22 03:29 PM
USA
USA
I like to use a stock looking aluminum Mopar factory with vacuum advance recurved by me, especially on street and strip cars to make most folks looking think whistling It be stock, honest whistling
B Block. Street/Strip, need to buy a whole ignition.
Re: Need to buy a good distributor [Re: Cab_Burge] #3096073
11/21/22 03:38 PM
11/21/22 03:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Same! I pull apart originals, clean them up, lube the centrifugal weights, add Mr. Gasket #925-B lightweight springs, and add the Hillman nylon collar since I usually destroy the stock ones taking them apart. I use them with an analog MSD 6AL and add a dial rev limiter and timing controller and the system has been flawless.
'63 Dodge 330
11.19 @ 121 mph
Re: Need to buy a good distributor [Re: GY3] #3096102
11/21/22 05:11 PM
11/21/22 05:11 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
https://progressionignition.com/shop/ols/categories/chrysler
Haven't used 1 but I been considering it. I'm also running a 470 street strip
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Need to buy a good distributor [Re: 67mprfan] #3096116
11/21/22 06:01 PM
11/21/22 06:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've never had issues with the O.E. stuff. When I built the racecar it was getting a crank trigger. I was just looking foe something to spin the rotor to the cap. I bought a 440 source clearance part that had no electronics for $25. Billet aluminum, polished, ball bearing, brass cap terminals. Diameter isn't bad either. I did have to clearance the edge of the cap to fit against this intake. Been running it for 10 years with MSD 7AL2. Flawless.
Doug
Re: Need to buy a good distributor [Re: hudsonhornet7x] #3096128
11/21/22 06:59 PM
11/21/22 06:59 PM
I'm not sure which brand and model ECU to use, sorry confused
I buy all the MSD older race boxes like the MSD404b,404C, MSD7, MSD7C and so on to use on my street and strip builds along with the proper Mallory or MSD race coils up
I've had one MSD7 die on me while racing years ago on my old pump gas Duster whiney
Only one luck
Re: Need to buy a good distributor [Re: Cab_Burge] #3096180
11/21/22 10:13 PM
11/21/22 10:13 PM
USA
USA
Thanks all for your experiences. It seems as though there are more options than I thought previously. Some of them are pretty trick! I wonder who makes the Summit brand? Also, does anyone here use Davis Unified Ignition (DUI)? The MSD unit is probably what I will buy, but I want to educate myself.
Re: Need to buy a good distributor [Re: hudsonhornet7x] #3096259
11/22/22 10:32 AM
11/22/22 10:32 AM
Pretty sure Summit distributors are Firecore. Haven't heard much good about those. I have a BB Chevy stroker that I built...the owner brought me a Summit distributor for it. It looks ok, but we'll see when I get it running. Good friend has a Summit distributor in his B1 motor, but it's just a gutted unit used w/ a crank trigger.
Those DUI distributors are ridiculously HUGE. I suggest looking into them closely before getting one. They may work ok, but holy crap are they huge and ugly. I'm surprised they fit under some hoods, lol.
Even w/ the rust "issues" people complain about w/ the MSD distributors, I've never had a problem from one of them.
CHIP
Re: Need to buy a good distributor [Re: an8sec70cuda] #3096340
11/22/22 03:25 PM
11/22/22 03:25 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Halifax Hops is on the mopar boards and he has a pile of cores. Can build one up with any curve you want and all fresh and tested. I needed one about a year ago and he set it up for me. Been perfect.
I want my fair share
Re: Need to buy a good distributor [Re: GY3] #3096341
11/22/22 03:28 PM
11/22/22 03:28 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Same here. Mr. Gasket spring kit and use the mag pickup to trigger a 6AL, and I have a start/step retard for when the nitrous is activated.
If I ever go non-sequential EFI I'll weld the advance weights and continue to use it.
Re: Need to buy a good distributor [Re: Blusmbl] #3096342
11/22/22 03:32 PM
11/22/22 03:32 PM
moparx Offline
moparx  Offline
has anyone taken the chinesium "billet" distributors with the ball bearing shaft and replaced the guts with factory parts ?
maybe not worth considering.
beer
Re: Need to buy a good distributor [Re: moparx] #3110700
01/10/23 10:11 PM
01/10/23 10:11 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The Firecore distributors have evolved to be a very reliable and impressive distributor. There have been a lot of updates and upgrades.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Need to buy a good distributor [Re: SomeCarGuy] #3110705
01/10/23 10:55 PM
01/10/23 10:55 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
He's on A bodys only quite a bit.
America First!
Re: Need to buy a good distributor [Re: carnut68] #3110712
01/10/23 11:16 PM
01/10/23 11:16 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I recently went with the Summit brand distributor. It has the std mopar magnetic trigger & is slightly smaller on the cap than the MSD which I found was a pain. It's probably not the flashiest distributor on the market but is user friendly. Someone mentioned they fall apart but as yet, mine has been great.
