Who's Valve Springs to Use?
#3092273
11/07/22 12:22 PM
11/07/22 12:22 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
So you guys know my issues with the Hemi eating intake valve springs....Who's springs should I go with on this rebuild for just over .700" lift?
Remember, this is street/strip application.....I can post the new cam specs later when I get home.
Re: Who's Valve Springs to Use?
[Re: Dragula]
#3092276
11/07/22 12:24 PM
11/07/22 12:24 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
IMO the best are PSI springs with Xceldyne locks/retainers.
[Re: INTMD8]
#3092283
11/07/22 01:04 PM
11/07/22 01:04 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
IMO the best are PSI springs with Xceldyne locks/retainers. I second this
[Re: dvw]
#3092401
11/07/22 08:04 PM
11/07/22 08:04 PM
Posts: 2,504 PA
moparacer
PA
PAC here too.....Springs on my engine have been run 3 years with heavy stainless valves and hundreds of passes and yet to see any pressure loss.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Dragula]
#3092412
11/07/22 09:08 PM
11/07/22 09:08 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My first thought was, are they suffering from too much heat, not enough oil cooling? No spring will hold up well if it gets too hot. Figure that out and you might find it isn't your choice of springs so much as the heat. What springs are you running? Are they up to the task?
[Re: gregsdart]
#3092417
11/07/22 09:31 PM
11/07/22 09:31 PM
CSK
Pattison Texas
My first thought was, are they suffering from too much heat, not enough oil cooling? No spring will hold up well if it gets too hot. Figure that out and you might find it isn't your choice of springs so much as the heat. What springs are you running? Are they up to the task? This is by George Bryce, its about motorcycles but it applies to car heads also, good info, https://youtu.be/9KvRBzKjCho?list=PLB2-V7-On60DG44XrHYCVcjnL2yAoCUa2
[Re: EchoSixMike]
#3092467
11/07/22 11:56 PM
11/07/22 11:56 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
My Dad and I have used comp endurance springs in my 418". The original camshaft in 2015 used the same springs until this summer when we changed cams. 7 years and 3 drag weeks with no problem at .650ish of lift at the retainer. 80% of drag week for me is 3000-3500RPM cruise.
If you haven't I would have someone spec a camshaft that knows you plan to drive it on the street. What little you may lose in performance you will likely gain in longevity. My first camshaft mentioned above used lobes that comp normally uses for circle track stuff. The current camshaft was lobes from the "Low shock" line that is supposed to be softer on the valvetrain. The new cam only has one drag week on it, and that may be its last as its actually a little slower lol, still some things to try before we take it out though.
That all being said my old 360 had 4 drag weeks on it with some random Reed grind .650(on the card) solid roller. I used $100 K motion K800 springs and changed them every year before drag week. I never hurt one of those springs either but they were cheap enough I never ran them more than one season.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3092486
11/08/22 06:00 AM
11/08/22 06:00 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
For street/strip endurance applications, Isky Tool room or Manley Nextek springs.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#3092493
11/08/22 08:30 AM
11/08/22 08:30 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
All of the higher end Isky springs are PAC-alloy or PSI. I have never seen either break. I have seen them turn blue from heat but never fractured. I have a set of PAC springs that came off of a 540 Hemi with a +.700 lift solid roller. The owner wanted a smaller cam after the first few dyno pulls lol.
What are the OD and IH of the springs you are currenty using? I have the matching retainers also (stage V heads).
[Re: Jeremiah]
#3092503
11/08/22 09:15 AM
11/08/22 09:15 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
[Re: Dragula]
#3092505
11/08/22 09:19 AM
11/08/22 09:19 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
@Dragula - check your PMs
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: an8sec70cuda]
#3092517
11/08/22 10:09 AM
11/08/22 10:09 AM
Brad_Haak
Loudoun County, VA
I believe Dwayne set you and me up with the same PAC 1243 springs, but I have no experience using them at this point
[Re: Brad_Haak]
#3092524
11/08/22 10:55 AM
11/08/22 10:55 AM
INTMD8
Lake Villa Il
I don't know how aggressive the cam is or what the manufacturer suggests for springs but you might be able to run the same ones I use.
PSI 1575ML
With .710 lift it would be-
1.86 installed 228lbs
1.15 open 625lbs
1.4 diameter of the above saves a lot of weight over the 1.55 stuff.
Would say you need to measure actual lift rather than base the installed height on theoretical lift if you haven't already done so.
I think the strongest pushrods that fit is very important as well.
[Re: Brad_Haak]
#3092532
11/08/22 11:25 AM
11/08/22 11:25 AM
an8sec70cuda
I believe Dwayne set you and me up with the same PAC 1243 springs, but I have no experience using them at this point Yes he did. I'm on my 3rd set of them since 2006. I just changed them out when I freshened it up. They still pressure checked good both times.
[Re: an8sec70cuda]
#3092542
11/08/22 12:34 PM
11/08/22 12:34 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I prefer PAC sprinmgs myself. Always given me great service life, we run them on the heads up car as well. So cant say never broke one but 10,000+ rpm can do that
[Re: Al_Alguire]
#3092667
11/08/22 07:49 PM
11/08/22 07:49 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
PAC on my Hemi and 440 Sixpack. We use thousands of sets od PAC and PSI with no major issues with either.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
