Who's Valve Springs to Use? #3092273
11/07/22 12:22 PM
11/07/22 12:22 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So you guys know my issues with the Hemi eating intake valve springs....Who's springs should I go with on this rebuild for just over .700" lift?
Remember, this is street/strip application.....I can post the new cam specs later when I get home.
Re: Who's Valve Springs to Use? [Re: Dragula] #3092276
11/07/22 12:24 PM
11/07/22 12:24 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
IMO the best are PSI springs with Xceldyne locks/retainers.
Re: Who's Valve Springs to Use? [Re: INTMD8] #3092283
11/07/22 01:04 PM
11/07/22 01:04 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I second this
Re: Who's Valve Springs to Use? [Re: CSK] #3092395
11/07/22 07:42 PM
11/07/22 07:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have nothing but good things to say about Pac. Never broke any. They've showed zero loss in pressure on the two sets I replaced just on maintenance. Everything in the valve train is happy. Close to 600 passes on the lifters. Valve seats stay nice.
Doug
Re: Who's Valve Springs to Use? [Re: dvw] #3092401
11/07/22 08:04 PM
11/07/22 08:04 PM
PA
moparacer Offline
moparacer  Offline
PA
PAC here too.....Springs on my engine have been run 3 years with heavy stainless valves and hundreds of passes and yet to see any pressure loss.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Who's Valve Springs to Use? [Re: moparacer] #3092405
11/07/22 08:17 PM
11/07/22 08:17 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
PSI
"Any fool can know. The point is to understand"
- A. Einstein
Re: Who's Valve Springs to Use? [Re: Dragula] #3092412
11/07/22 09:08 PM
11/07/22 09:08 PM
gregsdart Online content
gregsdart  Online Content
My first thought was, are they suffering from too much heat, not enough oil cooling? No spring will hold up well if it gets too hot. Figure that out and you might find it isn't your choice of springs so much as the heat.
What springs are you running? Are they up to the task?
Re: Who's Valve Springs to Use? [Re: gregsdart] #3092417
11/07/22 09:31 PM
11/07/22 09:31 PM
Pattison Texas
Pattison Texas
This is by George Bryce, its about motorcycles but it applies to car heads also, good info,
https://youtu.be/9KvRBzKjCho?list=PLB2-V7-On60DG44XrHYCVcjnL2yAoCUa2
Re: Who's Valve Springs to Use? [Re: gregsdart] #3092418
11/07/22 09:31 PM
11/07/22 09:31 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
PSI, or the Isky toolroom premium stuff, depending on the requirements. S/F....Ken M
Re: Who's Valve Springs to Use? [Re: EchoSixMike] #3092467
11/07/22 11:56 PM
11/07/22 11:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My Dad and I have used comp endurance springs in my 418". The original camshaft in 2015 used the same springs until this summer when we changed cams. 7 years and 3 drag weeks with no problem at .650ish of lift at the retainer. 80% of drag week for me is 3000-3500RPM cruise.
If you haven't I would have someone spec a camshaft that knows you plan to drive it on the street. What little you may lose in performance you will likely gain in longevity. My first camshaft mentioned above used lobes that comp normally uses for circle track stuff. The current camshaft was lobes from the "Low shock" line that is supposed to be softer on the valvetrain. The new cam only has one drag week on it, and that may be its last as its actually a little slower lol, still some things to try before we take it out though.
That all being said my old 360 had 4 drag weeks on it with some random Reed grind .650(on the card) solid roller. I used $100 K motion K800 springs and changed them every year before drag week. I never hurt one of those springs either but they were cheap enough I never ran them more than one season.
68 Barracuda Formula S 340
Re: Who's Valve Springs to Use? [Re: Bad340fish] #3092486
11/08/22 06:00 AM
11/08/22 06:00 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
For street/strip endurance applications, Isky Tool room or Manley Nextek springs.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Who's Valve Springs to Use? [Re: turbobitt] #3092493
11/08/22 08:30 AM
11/08/22 08:30 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
All of the higher end Isky springs are PAC-alloy or PSI. I have never seen either break. I have seen them turn blue from heat but never fractured. I have a set of PAC springs that came off of a 540 Hemi with a +.700 lift solid roller. The owner wanted a smaller cam after the first few dyno pulls lol.
What are the OD and IH of the springs you are currenty using? I have the matching retainers also (stage V heads).
Re: Who's Valve Springs to Use? [Re: Jeremiah] #3092503
11/08/22 09:15 AM
11/08/22 09:15 AM
an8sec70cuda Offline
PAC springs on my hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Who's Valve Springs to Use? [Re: Dragula] #3092505
11/08/22 09:19 AM
11/08/22 09:19 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
@Dragula - check your PMs
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Who's Valve Springs to Use? [Re: Brad_Haak] #3092511
11/08/22 09:40 AM
11/08/22 09:40 AM
Dragula Offline OP
Dragula  Offline OP
Sorry, forgot to post cam specs.....I will get to it tonight...
Re: Who's Valve Springs to Use? [Re: an8sec70cuda] #3092517
11/08/22 10:09 AM
11/08/22 10:09 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I believe Dwayne set you and me up with the same PAC 1243 springs, but I have no experience using them at this point
Re: Who's Valve Springs to Use? [Re: Brad_Haak] #3092524
11/08/22 10:55 AM
11/08/22 10:55 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I don't know how aggressive the cam is or what the manufacturer suggests for springs but you might be able to run the same ones I use.
PSI 1575ML
With .710 lift it would be-
1.86 installed 228lbs
1.15 open 625lbs
1.4 diameter of the above saves a lot of weight over the 1.55 stuff.
Would say you need to measure actual lift rather than base the installed height on theoretical lift if you haven't already done so.
I think the strongest pushrods that fit is very important as well.
Re: Who's Valve Springs to Use? [Re: Brad_Haak] #3092532
11/08/22 11:25 AM
11/08/22 11:25 AM
Yes he did. up I'm on my 3rd set of them since 2006. I just changed them out when I freshened it up. They still pressure checked good both times.
CHIP
Re: Who's Valve Springs to Use? [Re: an8sec70cuda] #3092542
11/08/22 12:34 PM
11/08/22 12:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I prefer PAC sprinmgs myself. Always given me great service life, we run them on the heads up car as well. So cant say never broke one but 10,000+ rpm can do that
Re: Who's Valve Springs to Use? [Re: Al_Alguire] #3092667
11/08/22 07:49 PM
11/08/22 07:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
PAC on my Hemi and 440 Sixpack. We use thousands of sets od PAC and PSI with no major issues with either.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
