Intake question #3091709
11/04/22 08:36 PM
11/04/22 08:36 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I have a chance to pick up a Indy 4500-Max NIB in a parts trade. I currently have a Super Victor standard port. I have Indy EZ heads ,but I'm getting them opened to Max Wedge port, I would have to do them same for the Victor. What's the opinions on the Indy intake?
America First!
Re: Intake question [Re: carnut68] #3091713
11/04/22 08:41 PM
11/04/22 08:41 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Can you $wing having both intakes to test against each other?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Intake question [Re: carnut68] #3091760
11/05/22 02:14 AM
11/05/22 02:14 AM
What is the part # on the Indy intake? 400-3,440-3 or 440-3X?
All the Max wedge Indy intakes I've seen are Max wedge port size from the plenums all the way to the head mating surfaces.
I don't think the Eddy Victor M.W. intakes are that way scope
More air=more power up
Re: Intake question [Re: Brad_Haak] #3091775
11/05/22 06:22 AM
11/05/22 06:22 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
May just do that.
America First!
Re: Intake question [Re: Cab_Burge] #3091776
11/05/22 06:27 AM
11/05/22 06:27 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Didn't get a part # but from his pics 440 4500-MAX
America First!
Re: Intake question [Re: carnut68] #3091836
11/05/22 01:27 PM
11/05/22 01:27 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Get a picture of it.
You want be sure it’s not some variation of the mod man intake.
Personally, I’d just rework the super victor and be done with it.
Re: Intake question [Re: carnut68] #3091850
11/05/22 02:24 PM
11/05/22 02:24 PM
AndyF Online content
AndyF  Online Content
The Super Victor is a very good intake. Get it port matched and you should be good to go.
Re: Intake question [Re: carnut68] #3091909
11/05/22 11:14 PM
11/05/22 11:14 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
It's a 440-3 so I took it in trade mostly because they are discontinued. I didn't realize the difference in the port between standard a MW until I saw them side by side.
America First!
Re: Intake question [Re: carnut68] #3091939
11/06/22 08:55 AM
11/06/22 08:55 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Nice! I was afraid it was gonna be the -3X version, which is waaaay too big for your application.
Re: Intake question [Re: Brad_Haak] #3091942
11/06/22 09:29 AM
11/06/22 09:29 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I would not have traded for the 3X. I knew if it was 6.75 tall it was the 440-3. It's almost identical to the Victor. I think it was a good score.
America First!
Re: Intake question [Re: Brad_Haak] #3092014
11/06/22 02:38 PM
11/06/22 02:38 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I swapped out a -3 for a 3X and also swapped the carb from a 1050 dom (9375) to a Pro Systems 1200cfm. On a .720 (gross) lift 11.5:1, 4.50 bore 528, It picked up 3 tenths and 4 mph. I was using the 572-13 heads, I was more surprised than anyone shruggy cool
Re: Intake question [Re: Tig] #3092019
11/06/22 03:00 PM
11/06/22 03:00 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I'm only using the EZ heads and probably a .600 lift cam and a 1050 dommie.
America First!
Re: Intake question [Re: carnut68] #3092076
11/06/22 06:31 PM
11/06/22 06:31 PM
tboomer Online work
tboomer  Online Work
I have the Indy -3 on my 512 with an 1150 Dominator. The heads are the Edelbrock 77929 ( I think) that were taken out to Max Wedge ports. The Indy intake was then port matched to the heads... wave
Re: Intake question [Re: tboomer] #3092118
11/06/22 07:53 PM
11/06/22 07:53 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
The only thing I don't like about Indy single plane manifolds, is how they run the port divider into the plenum. I have 2x of their manifolds, the first one I sent to get ported & flowed came back without the dividers, they were cut right back & it made a huge difference on how the engine performed, so I sent the other one in a few years later & it came back with the dividers gone too. I have a Super Victor manifold as well & it didn't have the dividers in the plenum & it flows within 8 cfm of the Indys that have had work. The Victor is slightly taller than the Indys.
Re: Intake question [Re: rebel] #3092187
11/07/22 12:14 AM
11/07/22 12:14 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I'll have to compare the two.
America First!
