Intake question
#3091709
11/04/22 08:36 PM
11/04/22 08:36 PM
Posts: 3,149 Md.
carnut68
Md.
I have a chance to pick up a Indy 4500-Max NIB in a parts trade. I currently have a Super Victor standard port. I have Indy EZ heads ,but I'm getting them opened to Max Wedge port, I would have to do them same for the Victor. What's the opinions on the Indy intake?
America First!
Re: Intake question
[Re: carnut68]
#3091713
11/04/22 08:41 PM
11/04/22 08:41 PM
Posts: 1,117 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Can you $wing having both intakes to test against each other?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Intake question
[Re: carnut68]
#3091760
11/05/22 02:14 AM
11/05/22 02:14 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
What is the part # on the Indy intake? 400-3,440-3 or 440-3X? All the Max wedge Indy intakes I've seen are Max wedge port size from the plenums all the way to the head mating surfaces. I don't think the Eddy Victor M.W. intakes are that way More air=more power
Re: Intake question
[Re: Cab_Burge]
#3091776
11/05/22 06:27 AM
11/05/22 06:27 AM
Posts: 3,149 Md.
carnut68
Md.
What is the part # on the Indy intake? 400-3,440-3 or 440-3X? All the Max wedge Indy intakes I've seen are Max wedge port size from the plenums all the way to the head mating surfaces. I don't think the Eddy Victor M.W. intakes are that way More air=more power Didn't get a part # but from his pics 440 4500-MAX
America First!
Re: Intake question
[Re: carnut68]
#3091836
11/05/22 01:27 PM
11/05/22 01:27 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Get a picture of it. You want be sure it’s not some variation of the mod man intake.
Personally, I’d just rework the super victor and be done with it.
Re: Intake question
[Re: carnut68]
#3091909
11/05/22 11:14 PM
11/05/22 11:14 PM
Posts: 3,149 Md.
carnut68
Md.
It's a 440-3 so I took it in trade mostly because they are discontinued. I didn't realize the difference in the port between standard a MW until I saw them side by side.
America First!
Re: Intake question
[Re: carnut68]
#3091939
11/06/22 08:55 AM
11/06/22 08:55 AM
Brad_Haak
Loudoun County, VA
Nice! I was afraid it was gonna be the -3X version, which is waaaay too big for your application.
Re: Intake question
[Re: Brad_Haak]
#3091942
11/06/22 09:29 AM
11/06/22 09:29 AM
Posts: 3,149 Md.
carnut68
Md.
Nice! I was afraid it was gonna be the -3X version, which is waaaay too big for your application. I would not have traded for the 3X. I knew if it was 6.75 tall it was the 440-3. It's almost identical to the Victor. I think it was a good score.
America First!
Re: Intake question
[Re: Brad_Haak]
#3092014
11/06/22 02:38 PM
11/06/22 02:38 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Nice! I was afraid it was gonna be the -3X version, which is waaaay too big for your application. I swapped out a -3 for a 3X and also swapped the carb from a 1050 dom (9375) to a Pro Systems 1200cfm. On a .720 (gross) lift 11.5:1, 4.50 bore 528, It picked up 3 tenths and 4 mph. I was using the 572-13 heads, I was more surprised than anyone
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Intake question
[Re: Tig]
#3092019
11/06/22 03:00 PM
11/06/22 03:00 PM
Posts: 3,149 Md.
carnut68
Md.
Nice! I was afraid it was gonna be the -3X version, which is waaaay too big for your application. I swapped out a -3 for a 3X and also swapped the carb from a 1050 dom (9375) to a Pro Systems 1200cfm. On a .720 (gross) lift 11.5:1, 4.50 bore 528, It picked up 3 tenths and 4 mph. I was using the 572-13 heads, I was more surprised than anyone I'm only using the EZ heads and probably a .600 lift cam and a 1050 dommie.
America First!
Re: Intake question
[Re: rebel]
#3092187
11/07/22 12:14 AM
11/07/22 12:14 AM
Posts: 3,149 Md.
carnut68
Md.
The only thing I don't like about Indy single plane manifolds, is how they run the port divider into the plenum. I have 2x of their manifolds, the first one I sent to get ported & flowed came back without the dividers, they were cut right back & it made a huge difference on how the engine performed, so I sent the other one in a few years later & it came back with the dividers gone too. I have a Super Victor manifold as well & it didn't have the dividers in the plenum & it flows within 8 cfm of the Indys that have had work. The Victor is slightly taller than the Indys. I'll have to compare the two.
America First!
