Autometer tach poof -- fixed #3088301
10/22/22 01:02 PM
10/22/22 01:02 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
A couple weeks ago I drove to the local cruise and part way there (less than 3 miles) it just quit working. Other than the obvious loose or broken wire what else can go wrong? Do these suddenly go bad? Is there any kind of internal fuse? I will track down the power, ground and trigger wire this afternoon. Hope it's just a blown acc fuse or bad connection. If it is a dead tach, is autometer still the go to brand or is there something else you like?
Re: Autometer tach poof [Re: GomangoCuda] #3088348
10/22/22 04:25 PM
10/22/22 04:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Never had that issue, and a couple of mine are 30 years old or so.
Even the couple of cheap AutoGage tachs I have seem to be bulletproof.
1st thing to do is check connections & wiring.
Re: Autometer tach poof - fixed [Re: topside] #3088349
10/22/22 04:35 PM
10/22/22 04:35 PM
Found it. The trigger wire came out of a terminal block under the dash. Easy fix.
Re: Autometer tach poof - fixed [Re: GomangoCuda] #3088358
10/22/22 06:03 PM
10/22/22 06:03 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Cool was watching to see whast the outcome was.
Always good to see an easy fix
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Autometer tach poof - fixed [Re: 340SIX] #3088377
10/22/22 07:43 PM
10/22/22 07:43 PM
Guitar Jones Offline
I had an Autometer Monster tach in the race car, bought it about two years before the car was completed, after about two months of racing it started acting up, not reading correctly and generally erratic. I contacted Autometer, told them the situation and they asked me to send it back to them. They fixed it and sent it back to me free of charge. They are A OK in my book.
Re: Autometer tach poof - fixed [Re: Guitar Jones] #3088411
10/22/22 09:54 PM
10/22/22 09:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
my experiences were quite the opposite several year back with their top of the line computerized gauge set up. We could not get the speedo to calibrate and hold it. I probably lost over 40 + hours on that issue alone. I even had a scope on it tried both sine and square wave generators, used shielded wire for the signals, ran the separate from other harnesses. They kept sending me modules and speedometers;. I asked to speak with the engineer that designed it and was told they hire consultants so it wasn't possible. Out of frustration, we did what one is not supposed to do which is change more than one thing at a time, ( In this case it was 3). It started working and I had no desire to go back and try to figure out which of the 3 did the trick. shruggy i still have a box full of modules and speedos beer
