Re: No oil pressure after oil change
[Re: 71redcuda]
#3087118
10/18/22 11:07 AM
10/18/22 11:07 AM
Posts: 4,684 Wichita
GY3
Wichita
The oilfilter had oil in it when i changed it the first time so i think it might be the oil sending unit. Do not replace the sending unit and start the motor to see if the sending unit suddenly took a dump or you may risk engine damage> It's more effort but the correct and only way to address the issue at this point is as everyone has suggested, Pull the distributor and oil pump drive. Install a mechanical gauge and run the pump with a priming rod and drill motor. the correct direction is CW. (clockwise) Will do, thanks! When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together.
[Re: TJP]
#3087182
10/18/22 03:13 PM
10/18/22 03:13 PM
GY3
Wichita
When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together. One can also use a sharpie to mark the dist. base to the intake or block so it'll fire right up. I do that too! LOL!
[Re: GY3]
#3087193
10/18/22 03:41 PM
10/18/22 03:41 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together. One can also use a sharpie to mark the dist. base to the intake or block so it'll fire right up. I do that too! LOL! Sometimes I even get motivated and use a punch to mark them because I've had Sharpie rub off.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: Bob Stinson]
#3087218
10/18/22 04:31 PM
10/18/22 04:31 PM
Guitar Jones
When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together. One can also use a sharpie to mark the dist. base to the intake or block so it'll fire right up. I do that too! LOL! Sometimes I even get motivated and use a punch to mark them because I've had Sharpie rub off. I do that all the time, the sharpie works better for me because a little brake cleaner and a rag will erase it.
[Re: GY3]
#3087224
10/18/22 04:47 PM
10/18/22 04:47 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The oilfilter had oil in it when i changed it the first time so i think it might be the oil sending unit. Do not replace the sending unit and start the motor to see if the sending unit suddenly took a dump or you may risk engine damage> It's more effort but the correct and only way to address the issue at this point is as everyone has suggested, Pull the distributor and oil pump drive. Install a mechanical gauge and run the pump with a priming rod and drill motor. the correct direction is CW. (clockwise) Will do, thanks! When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together. Just roll the engine around to TDC #1. Look at the rotor so you don't end up 180 out. Slot in the drive will be parallel with or slightly off parallel with the crank, pointing towards #1 cylinder. Sharpie mark will get you close but timing should be reset.
[Re: 57Fury440]
#3087225
10/18/22 04:50 PM
10/18/22 04:50 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
He said he only ran it for 5 to 10 seconds. I don't think it had enough time to build up pressure. That's a long time unless he left it sit with the pan empty for a while and didn't put any oil in the filter.
