Re: No oil pressure after oil change [Re: 71redcuda] #3087118
10/18/22 11:07 AM
10/18/22 11:07 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by 71redcuda
The oilfilter had oil in it when i changed it the first time so i think it might be the oil sending unit.
Do not replace the sending unit and start the motor to see if the sending unit suddenly took a dump or you may risk engine damage>
It's more effort but the correct and only way to address the issue at this point is as everyone has suggested,
Pull the distributor and oil pump drive. Install a mechanical gauge and run the pump with a priming rod and drill motor. the correct direction is CW. (clockwise) twocents beer
Will do, thanks!
When pulling out my distributor and intermediate shaft, I find it easiest to take a quick pic with my cell phone to determine the clocking for easy reference to put it back together.
'63 Dodge 330
11.19 @ 121 mph
Re: No oil pressure after oil change [Re: GY3] #3087151
10/18/22 01:02 PM
10/18/22 01:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
One can also use a sharpie to mark the dist. base to the intake or block so it'll fire right up. beer
Re: No oil pressure after oil change [Re: TJP] #3087182
10/18/22 03:13 PM
10/18/22 03:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I do that too! LOL!
'63 Dodge 330
11.19 @ 121 mph
Re: No oil pressure after oil change [Re: GY3] #3087193
10/18/22 03:41 PM
10/18/22 03:41 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I do that too! LOL!
Sometimes I even get motivated and use a punch to mark them because I've had Sharpie rub off.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: No oil pressure after oil change [Re: Bob Stinson] #3087218
10/18/22 04:31 PM
10/18/22 04:31 PM
Guitar Jones Offline
I do that too! LOL!
I do that all the time, the sharpie works better for me because a little brake cleaner and a rag will erase it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: No oil pressure after oil change [Re: GY3] #3087224
10/18/22 04:47 PM
10/18/22 04:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Will do, thanks!
Just roll the engine around to TDC #1. Look at the rotor so you don't end up 180 out. Slot in the drive will be parallel with or slightly off parallel with the crank, pointing towards #1 cylinder.
Sharpie mark will get you close but timing should be reset.
Re: No oil pressure after oil change [Re: 57Fury440] #3087225
10/18/22 04:50 PM
10/18/22 04:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by 57Fury440
He said he only ran it for 5 to 10 seconds. I don't think it had enough time to build up pressure.
That's a long time unless he left it sit with the pan empty for a while and didn't put any oil in the filter.
Re: No oil pressure after oil change [Re: Cab_Burge] #3087263
10/18/22 07:40 PM
10/18/22 07:40 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I had a buddy have that happen on an 81 B- van w/a 318. He ended up having it towed I , they did another oil change and all was well. He swore by Hastings filters, bought them by the case prior to this, I can't remember how many he threw away after/because of it. Brand new still in the case.
Re: No oil pressure after oil change [Re: CMcAllister] #3087320
10/18/22 10:37 PM
10/18/22 10:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agreed, up
