Speaking of Steering Boxes #3083202
10/04/22 11:42 AM
10/04/22 11:42 AM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
Thinking of overhauling/rebuilding the steering box in my two wheel drive 1979 Dodge D-Series. Just wondering if anyone here has attempted this themselves? Looking for any tips, hints, or any other information available. Any good videos out there? I know the steering box is a Saginaw Unit (GM style) box with maybe some differences? Thank you in advance.
Re: Speaking of Steering Boxes [Re: OrangeProwler] #3083220
10/04/22 12:36 PM
10/04/22 12:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’m all ears on this myself, rebuilt box is $300 kit should be much less
Re: Speaking of Steering Boxes [Re: cudaman1969] #3083317
10/04/22 05:53 PM
10/04/22 05:53 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Is the same Saginaw 808 box as Chevy. That is all that I have.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Speaking of Steering Boxes [Re: cudaman1969] #3083319
10/04/22 05:56 PM
10/04/22 05:56 PM
moparmarks Offline
moparmarks  Offline
145.00 at Autozone.
https://www.autozone.com/suspension...last-power-steering-gear-7515/858779_0_0
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Speaking of Steering Boxes [Re: moparmarks] #3083541
10/05/22 12:36 PM
10/05/22 12:36 PM
Middle of A Field
O
O
Middle of A Field
Thank you everyone. I think I'll still try to rebuild it myself. Some other builders have the box even priced more plus shipping. On the flip side of that some of the builder's quality has also slipped from what I've read recently as well. I also realize some builders use an oversized bearings which I don't think I would need for my application anyways for something that cruises around these days. Thank you all again.
Re: Speaking of Steering Boxes [Re: OrangeProwler] #3084060
10/07/22 01:29 PM
10/07/22 01:29 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
If your issue is just seals those are easy especially the pitman arm side. I have been any further inside a steering box since jr college auto shop days, back about 35 years ago.
Adjusting the play out of one is also easy without a rebuild/ just don't overdo it.
Re: Speaking of Steering Boxes [Re: volaredon] #3084130
10/07/22 07:52 PM
10/07/22 07:52 PM
Middle of A Field
O
O
Middle of A Field
Thank you.
Re: Speaking of Steering Boxes [Re: OrangeProwler] #3084146
10/07/22 08:49 PM
10/07/22 08:49 PM
Guitar Jones Offline
Unless you are replacing worn parts you technically aren't rebuilding it, you are just resealing it and adjusting it. If it isn't leaking just adjust it. The trick is adjusting it at center position which may not be when the wheels are straight.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Speaking of Steering Boxes [Re: Guitar Jones] #3084378
10/08/22 05:14 PM
10/08/22 05:14 PM
Middle of A Field
O
O
Middle of A Field
If there is any worn parts I would consider replacing them or if it's good insurance just a replace the bearings in there since it has see 130k miles of use. Mainly I would like to reseal it at a minimum and repaint/refinish.
Re: Speaking of Steering Boxes [Re: OrangeProwler] #3085079
10/11/22 11:28 AM
10/11/22 11:28 AM
Middle of A Field
O
O
Middle of A Field
Is there a brand of kit that's better than the other? I see Gates and Edelmann brands floating around. Just wasn't sure if one is better than the other? Thank you in advance again.
