Re: Speaking of Steering Boxes
[Re: cudaman1969]
#3083319
10/04/22 05:56 PM
10/04/22 05:56 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I’m all ears on this myself, rebuilt box is $300 kit should be much less 145.00 at Autozone. https://www.autozone.com/suspension...last-power-steering-gear-7515/858779_0_0
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: OrangeProwler]
#3084146
10/07/22 08:49 PM
10/07/22 08:49 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Unless you are replacing worn parts you technically aren't rebuilding it, you are just resealing it and adjusting it. If it isn't leaking just adjust it. The trick is adjusting it at center position which may not be when the wheels are straight.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
