Re: Best option for straight plug big block cylinder heads?
[Re: RTSrunner]
#3078809
09/19/22 05:25 PM
09/19/22 05:25 PM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Edelbrock hasn’t used powdered metal seats in any heads in at least a couple of years.
[Re: fast68plymouth]
#3078854
09/19/22 08:41 PM
09/19/22 08:41 PM
Posts: 2,255 IL
furious70
IL
I've got a manual steering box for a C body...2 actually I thought I might need to fit turbos but I made do. Borgeson box is a popular swap now, we put one in my brother's charger to not have to beat up the headers.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Blusmbl]
#3078931
09/20/22 01:44 AM
09/20/22 01:44 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
KG did my Eddy Performer RPM heads. The work looked good except for a little clean up needed around the valve guides. I don't have before and after flow bench comparison.
If the E-street heads are the same as RPM minus the plug angle mine might be a good example of the work.
I had to use 4.5" bore head gaskets to clear the chamber. That means there's a bit of a step down into the 4.375 bore.
[Re: feets]
#3078999
09/20/22 11:23 AM
09/20/22 11:23 AM
fast68plymouth
So. Burlington, Vt.
For a stock stroke combo, if going with the KG porting on Ede heads...... I’d forgo the chamber porting. They don’t need to be made any bigger.
As a footnote....... new, assembled, unported B1BS heads are a touch over $3k now.
[Re: furious70]
#3079094
09/20/22 05:29 PM
09/20/22 05:29 PM
Posts: 8,164 Plymouth, MI
Blusmbl
Plymouth, MI
Good call, I don't think I want to give up any compression. The cnc port work looks good but Dwayne's flow bench will tell the tale! Will be really curious to see if their program is as good as what Modern used on the Stealths and Edelbrocks. I've got a manual steering box for a C body...2 actually I'm worried with how nose heavy the car is that the manual box would be a pain to steer, but I'm tempted for the weight savings alone. I drove a '67 Imperial with no power steering belt for about 3 months but that was absolutely brutal, lol. It looks like the steering box isn't the tight spot though, the starter is. I need to pick up the TTI 1 7/8" headers to see how different they are compared to the Hookers. Thanks guys!
[Re: Blusmbl]
#3079191
09/21/22 12:30 AM
09/21/22 12:30 AM
feets
Senior Management
Senior Management
Irving, TX
I've got the TTi C body headers but the engine is still on the stand.
[Re: Blusmbl]
#3079248
09/21/22 10:29 AM
09/21/22 10:29 AM
fast68plymouth
So. Burlington, Vt.
The MCH program removes a pretty substantial amount of material. The intake port ends up with 15cc more volume than a TF240(240 vs 255).
At this point, I don’t know what the runner volume of the KG program is....... but I’ll measure one when they get here.
#3079269
09/21/22 11:50 AM
09/21/22 11:50 AM
Posts: 1,122 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Do the KG CNC heads get a better valve job than the OOB E heads come with? That's a helluva sharp lip under (above the valve) the exhaust seat in the pics above...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3079280
09/21/22 12:08 PM
09/21/22 12:08 PM
fast68plymouth
So. Burlington, Vt.
Let’s just say, regarding the heads in the pics........ I think there is “some” additional flow available by finessing what’s going on around the valve seats. Whether that ended up being 1cfm or 10cfm could only be determined by testing.
Assuming the valve seat config doesn’t hold it back, it certainly “looks” like the intake port is 300cfm capable.
I’m pretty sure the ones coming to me will still have the Ede VJ.
[Re: dart games]
#3079347
09/21/22 04:04 PM
09/21/22 04:04 PM
Posts: 43,152 Bend,OR USA
Cab_Burge
b1 heads are junk stay far away from them.had 3 motors with them.ran faster with indy sr heads.my next motor will have indy heads.plus indy heads are racer friendly.dont need special everything like b-1 heads.also b-1 heads are heavy.b-1 heads are not fot the budget racer I've had the opposite results on B1 heads compare to Indy SR, Indy 440-1 with their stock rocker arms single shaft set ups and a lot better results comparing CNC ported 440- 1 to a set of original B1 with their single shaft set up on engine dyno testing as well as at the track racing them : : work: I had the same thing(results) on a 426 street hemi motor compared to B1 motors, blown 484 C.I. 426 street Hemi motor with a Little Field 10:71 roots type blower dyno tested made 924 HP at 7300 RPM after a lot of tuning on the dual Carb Shop 1050 CFM blower carbs compared to a cast B1 intake with a single Dam Best 1450 CFM carb making 920 HP at 7000 RPM Flow tests reveal 370 CFM at 28.0 inches at .700 valve lift on the 440-1 intakes and the B1 heads on the same bench flowed 430 CFM at .700, .800 and at .900 lift Sorry for your bad results, who prepared your heads?
[Re: Blusmbl]
#3079348
09/21/22 04:10 PM
09/21/22 04:10 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Inoperative power steering steers way more difficult than manual steering. Can't compare the two.
[Re: an8sec70cuda]
#3079433
09/21/22 09:18 PM
09/21/22 09:18 PM
Blusmbl
Plymouth, MI
300 seems like a realistic number, compared to what 440 Source was claiming for their CNC port jobs, where it was up in the 320 range. I'm guessing 300 is a solid 40 cfm above what I have now, so the 2 hp per cfm rule would be an 80 horse gain on my shortblock, but I'm going to be limited by potentially the carb and possibly the headers if I don't upgrade... so it's maybe a 50 hp improvement going to ported Edelbrocks over my 906's. That should get me 3 tenths according to the Wallace calculators, and I'd be happy with that. Inoperative power steering steers way more difficult than manual steering. Can't compare the two. True, between the p/s ratio being quicker and also still trying to move fluid around in the box, it's not a fair comparison. I have gone from power to manual on my '68 Charger though, and it wasn't bad. This has an easy 300+ extra pounds on the nose so I'm not sure how much worse it would be.
[Re: Blusmbl]
#3079444
09/21/22 09:57 PM
09/21/22 09:57 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
if you do go with 440 source heads, as was said earlier in this discussion , get a bare set, the source valves were not up to what I would use ever again.
[Re: an8sec70cuda]
#3079579
09/22/22 11:01 AM
09/22/22 11:01 AM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Inoperative power steering steers way more difficult than manual steering. Can't compare the two. That's it guys, hit the gym...let's go
[Re: HardcoreB]
#3079758
09/22/22 08:48 PM
09/22/22 08:48 PM
Blusmbl
Plymouth, MI
That's it guys, hit the gym...let's go Alright, I'll be totally upfront, I think I wasted everybody's time with this- I'm sorry. Did more investigating on the TTI 1 7/8" headers and there is a special note on the C body fitment guide that they work with angle plug heads, and list Indy EZ's, the angle plug Edelbrock RPM's, and Trick Flows. The B body notes indicate only their 2" headers fit with angled plugs, but the C body 1 7/8" ones do. If the 1 3/4" headers are going to hold a head swap back, and the new headers fit angled plug heads, I really don't think I can justify a CNC ported Stealth or E-Street when an OOTB Trick Flow 240 is a better head in pretty much every measurable category and near the same price point, plus have room to grow if I ever go with a 512 kit in the future.
[Re: Blusmbl]
#3079768
09/22/22 09:05 PM
09/22/22 09:05 PM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
300 seems like a realistic number, compared to what 440 Source was claiming for their CNC port jobs, where it was up in the 320 range. I'm guessing 300 is a solid 40 cfm above what I have now, so the 2 hp per cfm rule would be an 80 horse gain on my shortblock, but I'm going to be limited by potentially the carb and possibly the headers if I don't upgrade... so it's maybe a 50 hp improvement going to ported Edelbrocks over my 906's. That should get me 3 tenths according to the Wallace calculators, and I'd be happy with that. Inoperative power steering steers way more difficult than manual steering. Can't compare the two. True, between the p/s ratio being quicker and also still trying to move fluid around in the box, it's not a fair comparison. I have gone from power to manual on my '68 Charger though, and it wasn't bad. This has an easy 300+ extra pounds on the nose so I'm not sure how much worse it would be. The 2 horsepower per cfm is doable but keep in mind if the heads are flowing 300 cfm@.700 and you are running a .550 lift cam you aren’t using the available horsepower.
[Re: Blusmbl]
#3079818
09/23/22 01:54 AM
09/23/22 01:54 AM
Posts: 268 Anchorage, Alaska
metallicareload
Anchorage, Alaska
FWIW, I'm using tti 1 7/8" headers with Trick Flow heads in a B-body. The TTI headers were a huge improvement over the Hedman 1 3/4" headers RE fitting around the spark plugs
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
