Info on Chrysler Marine 426b Engine #3077320
09/14/22 08:50 PM
09/14/22 08:50 PM
Salem
Mbeal88 Offline OP
Mbeal88  Offline OP
Salem
Hello, Just wanted to pick the brains of some people who have some knowledge in this field. My buddy picked up and old 30' pleasure boat this past week that had been sitting in a marina for years. His plan is to cut it down and turn it into a Commerical crabbing boat. When he started tearing into it he found out it still had a motor in it. Its a Chrysler Marine engine, best i can read from the model # on the tag is model: 426b(W?)R10 Type: 610. Wondering exactly what it is, and also if its worth anything before he does something with it. I have attached some pictures, not the best quality, but can get more in the am.
Re: Info on Chrysler Marine 426b Engine [Re: Mbeal88] #3077337
09/14/22 09:47 PM
09/14/22 09:47 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
some of what my dad knows. if they had 2 engines, like a tug boat, 1 is std rotation, other is backward. oil pan is heavier than heck. most had solid lifter cam and rocker arms and 11.1 compression. some stuff will interchange but a lot is scrap. good luck.
Re: Info on Chrysler Marine 426b Engine [Re: Mbeal88] #3077365
09/14/22 11:04 PM
09/14/22 11:04 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Interesting! I bought one years ago from a friend. It was a fresh rebuild and a great 426 Wedge Block. The block was used by a friend and is still in use in his street car. If you need a transmission, intake, oil pan or exhaust manifolds let me know.
Re: Info on Chrysler Marine 426b Engine [Re: max_maniac] #3077448
09/15/22 09:49 AM
09/15/22 09:49 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think it's sexy. Save it.
2011 Drag Pak Challenger
Re: Info on Chrysler Marine 426b Engine [Re: max_maniac] #3077465
09/15/22 10:56 AM
09/15/22 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
One thing to be concerned about seeing you are on the Coast is the type of cooling the engine had , fresh water or raw water . If raw water , and this was an ocean vessel , the salt water can eventually do a number on the cylinder walls from the cooling side . If it had a closed /fresh water system with a heat exchanger that is obviously lessened .
Re: Info on Chrysler Marine 426b Engine [Re: JohnRR] #3077555
09/15/22 03:26 PM
09/15/22 03:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If it turns out the block is scrap from the rust, all of the stuff will bolt up to regular 440 block except the pistons. If I was going to go through the motor,I would build the 440 anyway as there are a lot more options for reasonable priced pistons.
Re: Info on Chrysler Marine 426b Engine [Re: rickseeman] #3077657
09/15/22 09:05 PM
09/15/22 09:05 PM
Salem
Mbeal88 Offline OP
Mbeal88  Offline OP
Salem
Update: I am going to save it, I'll try and post more pictures for anyone interested. It was a fresh water system, so hoping it isn't in too bad of shape. Buddy first told me it was a 426 Hemi at first, which obviously I could tell immediately when I saw the engine that it wasn't, but I've never driven anywhere so fast in my life lol
Re: Info on Chrysler Marine 426b Engine [Re: Mbeal88] #3077668
09/15/22 09:19 PM
09/15/22 09:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Better hope it was properly winterized. Could have block cracks.
Re: Info on Chrysler Marine 426b Engine [Re: NITROUSN] #3077691
09/15/22 10:26 PM
09/15/22 10:26 PM
iagree scope twocents
I had a 1965 426 wedge block magnafluxed that had freeze cracks on both sides and a casting flaw inside the crankcase area under the #4 cylinder that wasn't found when it was magnaflux puke whiney
It was supposed to be a virgin stock motor, it wasn't whiney
It had been bored +.060 over and had some taper needing another bore job so it ended up at 4.320 bore size which made piston choices a lot easier for the overhaul. up:
