Interior heat, what do you use? #3074122
09/04/22 09:01 AM
09/04/22 09:01 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well, I went to a car show the other day, and realized without carpeting, there is a lot of interior heat in the car. Its a Prostreet car where I want to keep the weight down, what products do you guys really like?
Re: Interior heat, what do you use? [Re: Dragula] #3074136
09/04/22 10:29 AM
09/04/22 10:29 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
My car has dynamat, they also have a super light mat too.
Re: Interior heat, what do you use? [Re: Dragula] #3074178
09/04/22 12:13 PM
09/04/22 12:13 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Try using Microspheres...mix them into some paint and apply to the floors/firewall. will provide a layer of thermal and vibration dampening.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Interior heat, what do you use? [Re: rickraw] #3074262
09/04/22 05:49 PM
09/04/22 05:49 PM
Dragula Offline OP
Dragula  Offline OP
Too heavy and too thick....
I am looking at this:
https://www.summitracing.com/parts/hsp-770003
Re: Interior heat, what do you use? [Re: Dragula] #3074308
09/04/22 09:28 PM
09/04/22 09:28 PM
Ambridge, Pa.
Ambridge, Pa.
There’s also lizard skin. Never used it but I heard it works.
Re: Interior heat, what do you use? [Re: Dragula] #3074313
09/04/22 10:11 PM
09/04/22 10:11 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
How much could carpet weight?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Interior heat, what do you use? [Re: A39Coronet] #3074317
09/04/22 10:18 PM
09/04/22 10:18 PM
Dragula Offline OP
Dragula  Offline OP
The stock front half weighed a bunch...I want to put down somthing lighter when I redo the interior.
Re: Interior heat, what do you use? [Re: Dragula] #3074386
09/05/22 07:39 AM
09/05/22 07:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use stock carpet in mine. I need to get a headliner in my car, its the leading cause of becoming medium rare in the staging lanes.
After a few hours on the road EVERYTHING is hot. 2013 is probably the hottest drag week I have done. There was a day where you couldn't hold onto the cage because it was so hot.
68 Barracuda Formula S 340
Re: Interior heat, what do you use? [Re: Dragula] #3074650
09/06/22 03:06 AM
09/06/22 03:06 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I think you can get it with or without the jute backing pad. Jute free probably much lighter but loses some of the insulation obviously. Still retain oe look if that's at all a concern.
Re: Interior heat, what do you use? [Re: A39Coronet] #3074713
09/06/22 10:04 AM
09/06/22 10:04 AM
Dragula Offline OP
Dragula  Offline OP
Is that the crap on the back side of it that I have to vacuum out from every nook and cranny? That might be an option if they offer it that way...The front piece was really heavy for carpet. I have not removed the back piece yet. I just want nice thin carpet, but I need somthing underneath for the heat. I don't care about the sound, the car is loud as ..... anyways.
Re: Interior heat, what do you use? [Re: Dragula] #3074727
09/06/22 10:59 AM
09/06/22 10:59 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The jute backing is where most of the weight is. I scraped all of mine off in the Road Runner. The cheap lightweight carpet, never looks good IMO.
69 GTX 68 Road Runner
Re: Interior heat, what do you use? [Re: JERICOGTX] #3074743
09/06/22 11:50 AM
09/06/22 11:50 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I used marine carpet to save weight.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Interior heat, what do you use? [Re: BloFish] #3076243
09/11/22 08:22 AM
09/11/22 08:22 AM
pa
572charger Offline
572charger  Offline
pa
dynamat 70 % quieter in side the car and much cooler
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Interior heat, what do you use? [Re: 572charger] #3076315
09/11/22 02:34 PM
09/11/22 02:34 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I used eastwood's version of dynamat to line the doghouse in my van. Big difference in heat and noise.
Re: Interior heat, what do you use? [Re: Bad340fish] #3076464
09/12/22 06:17 AM
09/12/22 06:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I use stock carpet in mine. I need to get a headliner in my car, its the leading cause of becoming medium rare in the staging lanes. laugh2
